I need an arduino temperature and humidity sensor WITHOUT Wifly
Hi all, I am looking to make an arduino temperature and humidity sensor with an onboard display. I am fairly new to arduino but do have electronics experience. I am looking to just look at the thing and be able to read the temperature and humidity without having to go into the other room and kick someone off of the computer. I currently have an arduino uno, a RHT03 Humidity and Temperature Sensor, several 7 segment displays, enough LEDs to make a led matrix or clock type setup, and a Nokia 5110 graphic LCD with arduino board (which I could remove if needed) found at https://www.sparkfun.com/products/10773
Any help would be greatly appreciated. Thank you all.
Professorred
Jayefuu5 years ago
You have all of the components, what part are you struggling with?
Break it apart into blocks, get each of them working by themselves then work on getting it all working together.
James
professorred (author)  Jayefuu5 years ago
I am not sure where to go with the code. None of the instructables that I have seen deal with multiple sensors with only one data pin. I have found ones for temperature only but do not know how to adapt that to add the humidity sensor.
The datasheet for it explains that the 1-wire bus is proprietary. This page has an example sketch you can read and use.
Thank you. however, none of the codes that I can find through there can be verified. Every time I try, I get a long list of errors. I may have started too far for my level of knowledge of programming but I should be able to use a pre written code. I am not understanding what is going wrong.
