I need help setting up a 2Mhz oscillator circuit
So here's the backstory : Last night I was poking around in our shed looking for ..... when I came across a box of old electronics. Inside was a lot of old parts, from about the 1970's, a few 555's and 741's and a big 28 pin chip I didn't recognize. After plugging the numbers on the chip into google (AY-3-8500) I found out that it was freaking pong on a chip. Apparently my dad had bought it as a kit in the 70's but never got around to make it.
So I took a look around the net for schematics and found
http://www.electronixandmore.com/project/pongman/
http://www.datasheetarchive.com/pdf-datasheets/DataBooks/Book241-59.pdf
Here's the problem, I don't have easy access to the 90uH inductor in the schematics or a 2Mhz crystal.
So how can I create the 2Mhz I need to run the chip? It's the only thing between me and pong X(
1-10 of 24Next »
greendude (author) 9 years ago
UPDATE: Everything works, no idea why Ok I have the paddles working but I have no idea why they work. Working off the datasheet diagram instead of hooking pot pin 1 to the 10k Ohm resistor, hook it between Vss and the 0.1uF cap, pin 2 connects to pin 3 and pin 3 connects to between the 0.1uF cap and the 10k Ohm resistor, instead of to Vcc. I'm happy that I have pong working but a little annoyed that I have no idea why. Thanks to everyone that helped, especially you gmoon.
greendude (author)  greendude9 years ago
One small problem, the bats are a little glitchy and oscillate up and down every 5 or so second, it wouldn't be a problem if the oscillations were small but they are about 1/3 of the screen :S Any ideas?
Hah, so everything works now, except only the ball is displayed on the screen, I should be able to fix that by playing around with the 4071 chip.
gmoon greendude9 years ago
Cool. Great to see the next gen resurrect a project Dad never finished (I broke more of my Dad's stuff than I fixed...) I'm sure those logic gates matter.
greendude (author)  gmoon9 years ago
Haha, yeah me too :P The ball, scoring and feild are all operational now, just having a bit of a problem with the damn paddles (kind on essential :P)
You'll get it...
Ok, Here's an interesting twist, If I connect either side of the 0.1uF caps in the right and left paddle circuits the paddles display on the screen (somewhat glitchily, but they are there). I tried shorting the cap and that doesn't work either (well sort of, but I have to be touching the 220 Ohm resistor instead of the cap ><). I was thinking the pots are too big, but I'm using 1M ohm pots like in the diagram. Any suggestions?
So I went and did some work before coming back to ask another question: A 4Mhz crystal and a 4017 decade counter chip should work if I: Connect the crystal to the "clock" pin of the 4017, connect Q2 to the rest pin of the 4017 and also to the clock input pin of the Ay-3-8500 This means that every 2nd high that goes into the 4017 will output a high and reset the 4017, halving the 4Mhz down to 2Mhz. Oh and I'd run it at 6v since the datasheet says the 4017 tops at 2Mhz at 5v, it should be a bit higher at 6v, just to be safe Am I right? or am I just an idiot going down the wrong path? (thanks for all the help so far too :D, it'll be pong time in no time)
Anyone?
There's an "Alternate 2mHz Osc." speced out on the PDF you provided. It uses a 2mHz crystal and two CMOS gates (4001 or 4011), along with a few other components.
1-10 of 24Next »
