loading
I need help with this code
Hello,
I'm creating a PIR Sensor Alarm with Arduino. I'm using Arduino Uno, PIR Sensor, Breadboard, LED, Piezo Buzzer, TTL JPEG Camera, SD Card and SD Card Module (Breakout Board)
I tested my code and it didn't give me any errors. However, the LED and the Buzzer are on all the time, my idea is to have them on once the PIR Sensor detects motions. I know that I'm having problem with the code. Therefore, I'd appreciate it so much if someone could find out which parts of my code should I change.
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
int pirPin = 7;
int ledPin = 8;                // choose the pin for the LED
int pinSpeaker = 10;           //Set up a speaker on a PWM pin (digital 9, 10, or 11)
int minSecsBetweenEmails = 60; // 1 min
long lastSend = -minSecsBetweenEmails * 1000l;
byte ZERO = 0x00;
byte incomingbyte;
SoftwareSerial mySerial(2,3);          // Set Arduino pin 2 and 3 as softserial
long int a=0x0000,j=0,k=0,count=0,i=0;
uint8_t MH,ML;
boolean EndFlag=0;
File  myFile;
void SendResetCmd();
void SetBaudRateCmd();
void SetImageSizeCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
void setup()
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(pinSpeaker, OUTPUT);
  Serial.begin(9600);
Serial.begin(115200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
mySerial.begin(38400);
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
void loop()
  long now = millis();
  if (digitalRead(pirPin) == HIGH)
    digitalWrite(ledPin, HIGH);  // turn LED ON
    playTone(300, 160);
    delay(150);
    if (now > (lastSend + minSecsBetweenEmails * 1000l))
      Serial.println("MOVEMENT");
      lastSend = now;
    else
      digitalWrite(ledPin, LOW); // turn LED OFF
      playTone(0, 0);
      delay(300);
      Serial.println("Too soon");
  delay(300);
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq) {
    duration *= 1000;
    int period = (1.0 / freq) * 1000000;
    long elapsed_time = 0;
    while (elapsed_time < duration) {
        digitalWrite(pinSpeaker,HIGH);
        delayMicroseconds(period / 2);
        digitalWrite(pinSpeaker, LOW);
        elapsed_time += (period);
byte a[32];
int ii;
SendResetCmd();
delay(4000);                            //Wait 2-3 second to send take picture command
SendTakePhotoCmd();
while(mySerial.available()>0)
  incomingbyte=mySerial.read();
myFile = SD.open("pic.jpg", FILE_WRITE); //<strong><span style="color: #ff0000;">The file name should not be too long</span></strong>
while(!EndFlag)
  j=0;
  k=0;
  count=0;
  SendReadDataCmd();
  delay(200); //250 for regular
    k++;
    if((k>5)&&(j<32)&&(!EndFlag))
     a[j]=incomingbyte;
     if((a[j-1]==0xFF)&&(a[j]==0xD9))     //tell if the picture is finished
     EndFlag=1;
     j++;
    count++;
for(j=0;j<count;j++)
if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX);           // observe the image through serial port
Serial.print(" ");
for(ii=0; ii<count; ii++)
myFile.write(a[ii]);
Serial.println();
i++;
myFile.close();
Serial.print("Finished writing data to file");
while(1);
void SendResetCmd()
mySerial.write(0x56);
mySerial.write(ZERO);
mySerial.write(0x26);
mySerial.write(0x31);
mySerial.write(0x05);
mySerial.write(0x04);
mySerial.write(0x01);
mySerial.write(0x19);
mySerial.write(0x11);
mySerial.write(0x24);
mySerial.write(0x03);
mySerial.write(0x2A);
mySerial.write(0xC8);
mySerial.write(0x36);
MH=a/0x100;
ML=a%0x100;
mySerial.write(0x32);
mySerial.write(0x0c);
mySerial.write(0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write(0x20);
a+=0x20;
Thanks a lot!
tytower2 years ago
The PIR takes some time to set properly so you have to wait say a minute after switching on to set your devices . You dont seem to be turning the led offf after it has turned on the first time . Probably put an off statement after the delay 300 at the end of the loop and light it up again if the on condition persists
jkimball3 years ago
Is it possibly related to the fact that you need movement to turn the led and sound OFF?
The code to turn off the sound is also inside the "if (digitalRead(pirPin) == HIGH)" statement. Maybe take that out of the check so it always runs.
