I need to cut kind of thick plastic
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=103200&i=142SA69&tp=919
But the hole in my car is too small to mount the speaker on top, and the hole in the plastic is just slightly too small to fit the surround of the speaker if I mount it from the bottom. I figure it will be a lot easier to widen the hole in the plastic rather than in the car's sheet metal, but it's still not easy. Any tips? I've tried a box cutter knife, pocket knife, soldering iron, torch with soldering iron attachment, chisel, etc. Probably gave myself cancer from the fumes from trying to melt it. It's not terribly tough plastic, but it's kind of thick, so it's not easy. Plus it's difficult to cut a circle from the inside. I need to increase it from 13 cm diameter to 13.5 cm.
31
comments
Add Comment
http://www.mytoolstore.com.au/dremel-2615294309-flex-coupling-p-353.html
You don't have to cut it, just shave off some from the hole. A half-round file with the part in a small bench vise would work, file close to the jaws to keep it from vibrating much. Likewise a Dremel with a straight cylindrical burr would work nice. Don't know about using any kind of grinding or sanding tool with the Dremel as the plastic would likely clog them up pretty quick.
Does the entire circle need to be increased to get the speaker in, or just some high spots taken down?
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
