loading
Ideas and Methods for DIY Truck Topper
So in 5 months starting February I'll be getting my first vehicle. If I do get a truck, I'll be making my own topper out of wood. Now I have a reference picture but I want it out of wood just because it's more secure and looks pretty. Also because I will be making a door on the back that stands tall but can also be walked through. The first two photos is how I want to make the topper but I need methods and advice to do so. The third picture is how I want the door.
I'll try to answer any question when you have them but keep in mind I don't currently own a truck, this is for 6 months down the road.
Picture of Ideas and Methods for DIY Truck Topper
Downunder35m5 months ago
I would check first if you are allowed to do it.
When it comes to cars most countries have quite strict rules for "homemade additions".
There is a reason for it...
If you can still continue check the weight of everything first.
Wood can be heavier than you think, especially with hundreds of screws in it and several thick coats of varnish.
A very neat way to cut the weight down and get best stability would be to make the ouside from sheets of chipboard or wood laminate, whatever is cheaper to obtain.
A frame, some boiling water or steam and glue is all you need.
There are several Ibles about bending wood and making furniture, check a few ;)
jlowery5 (author)  Downunder35m5 months ago
And what searches would one use to find that out?
I hope you have more luck with your searches for other parts of your project, seems Google is not yet your friend.
Try this for example, includes links to Instructables as well.
Not really that hard is it? ;)
Thanks for the sarcasm but I'm set on it not looking terrible and being secure enough to protect the contents of the truck from theft. Let me ask the question a little more clear. Do you know what I would look for to find the legality of "homemade additions" being added to my vehicle?
No sarcasm here...
The fact is that in most modern countries anything you add to your car must comply with certain design criteria and be legal to use in terms of being safe in an accident.
Let's face it: The last thing you want is your wooden top to desintegrate in an accident and injuring people nearby.
And again without any sarcasm: The best place to ask is quite obvious:
The place that gives the registration to your vehicle or the one required to inspect a used car so the ownership can be transfered for road use.
Basically the same as building your own trailer from scratch.
In a lot of cases a certain size does not even require own numberplates.
But if it does it will be checked for compliance with road safety and structural safety.
I know in certain parts of the US it does not matter what you do to your car in terms of canopies or truck tops but that does not mean every design someone created in his backyard is actuall safe on the road.
Can you imagine why they abondoned wooden exteriors for cars and most trailer ages ago?
Your design might certainly look great when finnished but unless you happen to be a structural engeneer I still advise t double check the legal side first and than go for a design with as much "solid" wood as possible.
Panel designs with hundreds of screws are a thing I would not want to have permanently connected to my car.
Forgot to mention:
Using single sheets that are not laminated is the best option.
Multilayers thicker than 3mm can be a real pain to bend.
The single ones often only need a good soak in warm water to make them flexible enough to go around bends like you would have.
If there is any furniture makin store near you or your hardware store is well stocked you can use something more special than birch or pine for the last layer.
Or just use a nice stain if you want to stay on a budget.
Make sure to create enough layers to get proper stability.
8-10mm are usually sufficient unless you want the final piece without any internal support frames on the wood.
For a clean inside look with enough strength and thickness to use proper screws I recommend going to 12 or up to 15mm.
You won't get a better look than something that looks like one solid piece of wood ;)
If you get big enough sheets you can even cut the door walls so they would would match the grain of the last sheet used for the outside - makes it look like you carved it out of wood (if you are no expert).
