I'm thinking about buying a pocket watch...
I'm not certain about how this is entirely relevant to Instructables, but I need some help on picking out a pocket watch. (Perhaps I could write up a "How to buy a pocket watch" sort of thing...)
I've always loved mechanical things, parts working smoothly together, things that go tick, clockwork, blah blah blah. Plus, I've been told that I come across as saying we should take everything back to 1800's. ("We should use gold nuggets as currency, or even go back to the bartering system!" "Zeppelins kick ass!" "Get rid of cars, let's all ride bikes!") :D
Anyhow, I wanna buy a pocket watch for about one hundred American dollars. I'd like it to tick, I'd like it to be wind-up, I want to be able to see the clockwork inside, and I don't want it to fall apart after a week. Does anyone have any tips for me? Like, "Make sure it says '17-jewel,' or else it's no good."
On that note, if a watch is listed as having "17 Jewel Skeletonized Mechanical Movement," does that mean that it's wind-up?
How much of a problem is it if you buy a watch with a plain, smooth case? (I'm worried about scratching).
If it isn't too much trouble, I'd appreciate it if you'd share what watch/es you've had in the past.
1-10 of 16Next »
Honus10 years ago
If the watch is listed as a mechanical movement, then it will be a manual wind watch. There are automatic mechanical pocket watches, but they are pretty rare... Generally speaking, the greater number of jewels, the higher quality the movement is. If the movement is skeletonized, that means that the metal plates that form the base of the movement have been pierced through. Sometimes the bridges (extensions spaced off the main plates where the some of the jeweled pivots are located) on the movement are pierced through as well. Many mechanical pocket watches available today (this doesn't include antique or super high end pocket watches) use the same base movements, which in many cases is manufactured by ETA -probably the single largest manufacturer of mechanical movements. If it has an ETA movement, then it's probably a pretty good watch. Often what you are paying for is the finish or modifications applied to the movement, the construction of the case and the quality of the dial and crystal. It's not a problem to buy a watch with a smooth case- many watches are made that way to allow for the case to be engraved or monogrammed later. All cases will scratch over time. Hope this helps!
LeandroG1 Honus2 years ago
Automatic pocket watches are surfacing. Besides dubious quality Chinese pieces with European names such as Charles Hubert, and the totally stupid, tremendously expensive UR Werk 1001, in order of availability: Eterna-matic Golfer, Tissot Visodate, Citizen Leopard.
Just found about some Universal Genève automatic pocket watches that seem to be better available than the Tissot or Citizen; also, even rarers Citizen Seven star de luxe and a IWC prototype.
carbon (author)  Honus10 years ago
Ah, good. Thanks for the help!
I think sou!!!!
neilb32 years ago
I have bought all my Pocket watches from China and they are great, auto mechanical, hand wind or Quartz they are all great and very reasonable prices.
billbillt5 years ago
I have bought several mechanical ones from China on Ebay..They run from $8 to $15. I am very pleased with them.. There are many styles to choose from..
I purchased a mechanical Pocket watch from Wal-Mart for $20. It has glass panels on the front and back so you can see the mechanics and if you look right all the way through. However the finish is worn off where my chain rubs. But it is a very sturdy reliable little time keeper.
Kiteman10 years ago
If you want ticking, you want mechanical. If it's not mechanical, it's quartz, which is the crystal that keeps digital watches in step.
"Automatic mechanical" means there is a small pendulum within the watch that does the winding for you, driven by the movements of your body, but I've never seen an automatic mechanical pocket watch.
If you want a pocket watch just for show, try ebay. Look for hunter style watches or pocket watches linked to the rail network (I expect British Rail will be cheaper than US rail, as UK train guards stopped using pocketwatches more recently (I think)).
Jewels? The more the merrier - slivers gemstones (ruby ?) are used as low-friction, long-life bearings.
Kiteman Kiteman10 years ago
Oh, and chiming ones are often called repeaters.
1-10 of 16Next »
