loading
Image Processing Tutorial : What you do for your images?
Are you in possession of images you want to convert in to digital form? Or simply you would like to perform some operations to enhance their outlook?  Similarly if you just want to extract some useful information from them, all you need is a photo house that carries out image processing. This is where you can have a photo you want manipulated made  the input as you give  specified characteristics you want included. To do image processing, you may have to apply a set of signals that can give you   the desired results.
There are three distinct steps to follow in any image processing. They include:
Importing images using a scanner or a photography
Analyzing and manipulating images using enhancement and compression methods
Altering the results we obtain at the output level
There are plenty of reasons for carrying out image processing; the reasons and purposes are as follows:
So that you can easily observe the parts that are not visible
Restoration and sharpening the images for the purpose of making them look better
Image retrieval – if you are interested in any particular image, you can have it retrieved.
Identify the number of elements making up a pattern
Distinguish the object and its image.
There are   two methods that can be used in processing any images.
Digital
Analog
If you are analyzing hard copies and printouts, this is what is referred to as visual techniques.  It involves use of various fundamentals and image processing techniques.
You need to make use of technicians who are vast in image processing. They may use visual techniques and apply a combination of individual knowledge and experience in image processing.
If your pictures are in a digital form, you may employ digital processing techniques to manipulate those using computers. Images collected from sensors and satellites can be manipulated to get the real images or data.  To do this, you need experts who can take the images collected into a number of phases before coming up with the required images.  They must have the latest skills to help them get over flaws and get original information. The data or images collected may be taken through the following phases;
Pre-processing,
Information extraction,
Enhancement and display.
Other than image processing service, you may need team   to deal with computer graphics. This is where any desired image is manually made using physical models. It could include lighting, environment and natural scenes. This graphics can be used in animated movies, computer vision and plays. It can be used to create moving images to depict a story.
Generally, imaging is key in image processing. The designers should consider a number of factors including;
Human visual – where the designers consider the psychophysical process that takes place in human beings as they make sense out of information they see and receive.
Lastly in all these, ensure that you get a clipping path company that is vast in imaging and which can work hand in hand with you to ensure that you get the required results.
It would be nice more if you attach some video with this tutorial. Thanks I am from www.clippingpathlab.com
