loading
Induction Heating
High frequency induction heating is basically a very efficient way to heat ferrous metals. Induction heating uses an powerful magnetic field to induce currents within the surface of the metal being heated. This means that the coil will not get hot unless the material being heated transfers heat to it. Induction heating is very efficient because no heat is wasted, no heat is wasted because the coil does not produce heat, the heat comes from the workpiece being heated only.
Picture of Induction Heating
1-10 of 15Next »
frankiedog5 years ago
info unlimited has an induction heater you can buy
ekimh6 years ago
Check out these YouTube videos, Part 1 through 4 on a Magnetic Induction heater, 50,000 BTU out put at 16.29 amps input 240 volt single phase (3,910 watts)
http://www.youtube.com/results?search_query=capindres&aq=f
Capindres
jj.inc6 years ago
What do you need to run a coil, does a triple phase 120v outlet work, if so how would I wire it. or do I need a special driver like I have seen in all the how to's.
lyzyrdman (author) 8 years ago
Ya I am really working on an Instructable for a 180 kHz induction heater right now but I can't really post it until I am done for now I am waiting for the parts from Ebay to come. They should be here next week. My family might actually be getting an induction stove so I can also document that on here. For now I will post an Instructable on how induction heating works.
I would be interested in this.
neonjohn6 years ago
Hi guys.
I'm Neon John and designer of the induction heater featured at http://www.neon-john.com.  Someone sent me an invite to join this discussion.  Well, I'm here, in case there are any questions.
This is a good opportunity to announce a new higher power and much more reliable open source heater capable of at least 1800 watts.  Read about it here:
http://www.neon-john.net/Induction/Roy/Roy.htm.  Parts kits and completed units are available.
I can be reached at jgd(at)neon-john.com.
Thanks,
John
Am-Nuel7 years ago
 i'm looking for ible or induction heating scheme. do you guys have anything  like that?
garettc7 years ago
Very cool!
You might also check out Neon John's induction heater page--he's got a 1200 watt heater with plans, .pcb files to make your pc board, and a full description of what it's all about.
It's worth a look...
timmo_19497 years ago
This could be fun. I would like to use induction heating for very small scale metal casting. Could one use the parts from an induction cooker ? That is, if you had one that you could tear apart. Timmo
I got a slideshow here that I will update when the parts come so it might be worth taking a look at.
https://www.instructables.com/id/180_kHz_Induction_Heater/
1-10 of 15Next »
