loading
Infuse food coloring into wood
I made a vacuum chamber out off a mason jar, and attempted to infuse wood with food dye, using a brake bleeding vacuum pump.  The results were no better than if I painted the dye on.  All I got out of it was blue fingers (next time I will use rubber gloves).
Anybody got any suggestions?
1-10 of 14Next »
Kiteman4 years ago
What did you actually do? (Maybe your method needs fixing.)
WazIt (author)  Kiteman4 years ago
I place the wood in hot water in the chamber (mason jar) for around 10 minutes to open the pores, and then mixed in my dye. Then I set the cover and pump in place and started pumping. I only managed to get it to about 22, and left it for about another ten minutes. I did notice that I must have a leak in the chamber as the count on the gauge was down to about 10 at the end of the ten minutes.
After I allowed the wood to dry, and checked the penetration was not very significant.
designB0t WazIt3 years ago
I think time is the critical factor you may be missing.
I've been researching using a vacuum chamber to infuse wood with acrylic resin, and it seems that you need to keep the wood submerged and under vacuum for up to 45 minutes to eliminate air in the wood pores, and then release the vacuum to allow the fluid to be drawn back into the voids, which can take hours for small pieces or days for thicker/larger pieces.
Presumably similar principles will apply with water- or solvent-based aniline dyes.
Kiteman WazIt4 years ago
I would add the dye to the hot water straight away - you're filling the pores with unstained water, blocking the access of stained water.
Also, as Caitlinsdad says, the actual dye may be wrong for the wood. A fabric dye may do the job, especially one intended to use on cotton (cotton and wood fibres are chemically similar).
WazIt (author) 4 years ago
Tried clothing dye in boiling water, this time. Inserted the dry wood (thinner than the last time, only 1/8"). Got the vacuum up to 22 and left it for about 4 hours. Still only got little penetration.
Maybe it's time to change to pressure instead of vacuum? Force the dye in, the way they force in preservation treatments.
Tried it again this weekend, with food dye. I did not pre-soak the wood, but the results were no better. One of my co-workers dyes eggs, and I might try some of their dye....also might pick up some clothing dye and try that.
Dear All
I'm hopeless on computer, someone logged me onto this,please tell me the right part of this website to put these requests on:
1.Is there something which will lead audio(sound) out via a 3.5mm jack(for headphones etc) via a cable to a USB port or whatever its called to put it onto dvd/memorycard/computer beacause I'm trying to find a way to get the cassettes onto a PC so my friend can sort the sound out.
Alternatively(if there's no such thing as a special lead/connector/kit to put one together) if I play tapes through a speaker will sound of playable quality record onto a dictaphone with a memory card?
2.What kinds of outdoor paint will I need to use on treated plywood(strong stuff it's been there for ages)and then what varnish to put over it as the original paint(How do I remove it or is smoothing down/painting over with primer an option) as the painting I'm being asked to retouch/redo is faded and flaking off,no protection on it I presume
Also can I get a set of outdoor paints in several colours
What depth of penetration are you expecting? For cosmetic purposes, the wood will look dyed on the surface. After all, they poke zillions of tiny holes in lumber to apply the pressure treated wood treatment so it penetrates deeper. You might have to do the celery experiment with a living tree to see if it soaks up dyed water.
WazIt (author)  caitlinsdad4 years ago
I am attempting to get 100% penetration. I know Gibson have dyed living trees, they did not get perfect penetration, but have made some interesting looking guitars from the results.
1-10 of 14Next »
