3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Insulating Ducts
I was thinking about opening one side or the top of the "metal box" that "insulates" the out/intake ducts of HVAC unit, and filling that space with styrofoam popcorn used for shipping fragile stuff.
We recently had a couple of trees cut down in the backyard and now our HVAC unit is completely exposed to the sun for most of the day! We bought a shade to set up but I was thinking the styrofoam would just be a little bit more of a help!
What do you think?
All ideas and advice would be greatly appreciated!
7 comments
Jul 26, 2010. 1:19 PMcrapflinger says:
i would imagine that most waterfowl that have survived over history long enough to breed and continue their species are sufficiently insulated, what with the waterproof feathers and what not...wait, you said ducts, with a T
do you have a maintenance agreement on your HVAC system? if so i'd contact the people that you have the agreement with and ask them for ideas,
but, assuming your HVAC is similar to mine (packaged heat pump) there are two shiny ducts coming out of the back (output and return) that are in a sort of, squared cone of sheet metal (yeah, squared cone, 3 dimensional trapezoid?) that's screwed into the back of the HVAC, then the other end of the "cone" is attached to your house. assuming that there are no openings around the two round ports that come out of the HVAC itself you could just fill the "cone" with expanding foam insulation (the spray foam stuff).
or take said cone off, and use duct wrap (fiberglass insulation sheets with a Mylar backing) to wrap the ducts.
kind of surprising to me that they're not already insulated.
Jul 27, 2010. 8:25 PMGoodhart says:
*chuckle* I saw the T in ducts, but came here wondering why anyone wanted to insult ducts LOL I am tired and need to go to bed....
Jul 24, 2010. 9:07 PMTool Using Animal says:
photos always help
Jul 24, 2010. 8:47 AMcaitlinsdad says:
The HVAC unit that is outside should be designed to get rid of the heat to the outside air so I don't think you would want to insulate it in any way. It might help to shade the compressor part and insulate the cold return hose back into the house but you shouldn't need to add any insulation to the unit.
Jul 24, 2010. 11:40 AMNachoMahma says:
.  I think the OP is talking about the type of unit that has the compressor and evaporator in a single outside unit with air ducting between the house and the outside unit (very common on house trailers around these parts), in which case extra insulation would be helpful.
.  I'm not at all sure that packing peanuts would be the way to go. There is usually a lot of vibration in the area and the peanuts would probably compact in short time. How much heat will they take? I think I'd look at styrofoam (or other insulating material) sheets first.
.  Also need to make sure that the cold side can "breathe" or condensation will collect and cause corrosion/rust. Too much insulation may block needed air flow.
Jul 24, 2010. 11:46 AMcaitlinsdad says:
ah, the abandoned cars always blocked my view.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
