Is it possible to make a specialized spark gap device that operates similarly to a transitor?
I have a serious issue with utilizing an H-bridge to switch polarity of high voltage electromagnets. The voltage is roughly 110 DC rectified from mains. Every mosfet I use has exploded when I tried to switch the mosfets. I tried using relays but they keep arcing and tripping my breaker. I would very much like to know if it was possible to make a spark gap that works similar to a NPN transistor.
1-10 of 19Next »
dsanco2 years ago
You are looking for a vacuume tube. Generally more robust than the silicon counter parts. They have a grid separating two terminals to control current passage between them.
You're killing the things because you aren't handling the inductice kick-back properly.
Correct H bridge operation is
1       2
3       4
1.) 1 And 4 on
2,) 1 and 2 on
3.) 3 and 2 on
4.) 3 and 4 on.
2-3 happens ONLY when I =0 and 4-1 happens only when I=0
You CAN try putting VERY big diodes across each mosfet or relay contact. When I do it, I use a whacking big bridge rectifier for 4 nice, heatsinked diodes.
Steve
50ul84n3 (author)  steveastrouk7 years ago
I believe that the nature of my problem is being a little skewed. You seem to be under the assumption that I am having trouble with the kickback. What I really have a problem with is that during the switching of relay 1 and 4 to 2 and 3 the resistances of the airgaps between the contacts is less than 60 ohms thus allowing the electricity to short circuit from relay 1 to relay 3. The real question I wanted input on is that if a spark gap were to be made at 1.25 the distance the arc can occur, and a plate were placed halfway between the anode and cathode would applying a charge to the plate allow the arc to jump between the 2 terminals through the plate?
That is PRECISELY when the inductive kick will happen, and is clearly happening. The inductors do not want to change state !
They are already rectified and so therefore can not send a reverse voltage through the positive leads. There is also a diverter that I use to divert the kickback to ground but it only works if the relays can reach a resistance of >60 ohms before an arc is started. I also tested the circuit without the electromagnets and still get the same result so if you want to still claim it's a problem with the coils go ahead, but if my problem were that simple I would have gotten the answer from wiki.
Post your circuit. Where is this "rectification" acoss the coils ?
Steve
Here is my H-bridge, and it's not worth the breath to chide me for using paint.
As I suspected, the diodes are wrong. If you left the diodes in when you tested without the magnet, I am not surprised you blew the mosfets ! Which Mosfet did you use ? Did you check the Vg max ?
Steve
50ul84n3 (author)  steveastrouk6 years ago
the Vg max was somewhere close to 200v but I never used the mosfets with this exact circuit. I ran a switching test to double check the bias, when the mosfet exploded I chose to use relays instead. I know exactly where my problem is and the question I posted was whether a pseudo-vacuum tube / spark gap transistor were possible. I don't like the idea of using MOSFETs primarily because there will be absolutely zero heat dissapation capacity along with the circuit operating in a high ambient heat environment.
If you know your exact problem, you don't need an answer. I am telling you that the diodes, as drawn, are connected wrongly, and won't work. You are only switching an electromagnet, and not igniting a nuclear weapon.
Steve
1-10 of 19Next »
