3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is sugru safe?
Hello,
Doe's anyone know if it is actually safe to use sugru on our project?
I mean, is it safe to let a kid use something that got sugru on it, or to put sugru near our ear/mouth/eye?
11 comments
Oct 7, 2010. 11:41 AMcaitlinsdad says:
The warning on the package is for possible allergic reaction to certain chemicals in its uncured state. Now depending on what age child you are talking about, I would still exercise care with letting them handle any kind of plastic, even some water bottles turned out bad.  This is not a food-grade or medical-grade silicone product so I really wouldn't really let it contact sensitive areas let alone ingest it.  Best to email the sugru site for concerns on long term exposure.
Oct 7, 2010. 1:23 PMNachoMahma says:
.  According to the MSDS for Sugru (PDF), it's safe to ingest small amounts of cured product (see section 11).
Oct 8, 2010. 12:28 PMsteveastrouk says:
Ultimately it becomes food-safe silicone rubber.
Oct 8, 2010. 4:55 PMjwystup says:
What makes you think that? I saw this and haven't seen anything that says that this has changed: http://getsatisfaction.com/sugru/topics/is_sugru_food_safe
The answer comes directly from the sugru people. You probably shouldn't put it on things that your food touches regularly (like you could put it on a spoon handle or the bottom of a bowl, but I wouldn't start licking it)
Oct 9, 2010. 3:24 AMsteveastrouk says:
Hmm. I could have sworn I read it on the Sugru website, but I can't find it now.
In general silicone rubbers, when cured, are not "toxic" in any realistic sense, licking it or chewing silicones is extremely unlikely to be a hazard. Silicone oils, which are what rubber is made from are non-toxic enough for implantation in the body after all, and they are used in cosmetics.
We use a lot of silicone rubber and oils in our products at work, and our MSDS sheets make no mention of ANY hazard (except "may be slippery") "No known hazard from the cured product" features heavily.
Food-grade silicone is manufactured and monitored to make sure that there are no toxic elements present in the base-stocks.
Licking it wouldn't give me any problems - I must have done it many times to slip a pipe on a connector.
Steve
Oct 10, 2010. 2:19 PMdombeef says:
Yeah, but this is sugru, it is a putty before it becomes silicone.This must have different ingredients then regular silicone.
Oct 10, 2010. 2:30 PMsteveastrouk says:
That's down to the polymerisation they use. Maybe this stuff is crosslinked a bit to make the putty, and the final stage is done by the rest of the cure process.
Oct 10, 2010. 3:33 PMdombeef says:
Yeah, but the "polymerisation"( I have no idea what that is) could be toxic in _ ammounts
Oct 10, 2010. 7:54 PMNachoMahma says:
Polymerization is a process, not an ingredient.
.  Personally, I wouldn't use any silicone-based product in anything that came in contact with warm food but wouldn't be afraid to use it at room temperature or below. I'm not a toxicologist. YMMV.
Oct 11, 2010. 2:19 PMdombeef says:
Ok, thanks, and i saw the instructable on homemade sugru. if that is how real sugru is made, then it would be ok to have food on it, though i wont use it also
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
