Is there ANYTHING I can use old dial up modems for (other then dialing up the internet)?
Any old, or unique ideas on what I can do with them? I have one that is fairly fast (an old cable modem) one that is medium fast (an old DSL modem) and one 56k plain vanilla dial up.
Packet radio, for one. For the the dial ups, anyway. A normal dialup modem isn't optimized for radio, but it can work (slowly).
Cable modems can sometimes be hacked--not in an "underhanded" way (such as to get free internet). Rather to explore, modify and use the built-in web server / DHCP server, etc.
Might take some serious hacking, it it's not a well-documented modem.
One possible hack would be connecting the modem to a microcontroller and accessing the internet, for instance.
(I have a DIGI portserver someone sent me, which is essentially an ethernet <-> RS-232 connection.)
AFAIK, you can connect modems without using the telephone lines. Google "modem to modem direct connection".
But maybe you want more than a computer<->computer connection, and more like a printer server. If it's a USB peripheral, then you'd really have to know embedded systems.
Otherwise, for an old-school RS-232 peripheral, it might just work. Or controlling UCs (micro cont). Most can speak simple serial protocols.
Of course, a simple null-modem cable would work, too. ;-)
Current-loop serial interfaces are good over long distances as well, if that's what you need. Research the old teletype lines (and MIDI interfaces use current loop, too).
. You can do that with telephone modems, but a null modem cable works better. You can use a null modem cable, but Ethernet is faster. Most computers have E'net built-in, but, if you need a card, they can be found for < $20.
Well, I suppose it is "instructions" then, or at least, being pointed in the right direction for the proper instructions, since I am working blind on this one.
I mean, I have a tiny inkling of how the whole ethernet thing works where I am employed, but that is a bit more "over the top" then I need.
. Ethernet is pretty much the RS-232 of today (right behind USB). If you could install a serial printer back in The Good Old Days, you should be able to handle TCP/IP. . Much like you don't have to be able to rebuild a motor in order to drive a car, you don't have to know a lot about E'net/TCP/IP to get a small network to work - if you have setup a router at home, you probably already know just about everything you need to know.
If they want to send and receive faxes from their computer rather than using a service. I use to have DSL and I would have my phone line go to a splitter one side going into my DSL Modem and the other side going into a filter going into my modem for faxes. Worked great.
Most obviously, AWESOME project enclosures! Gut them and take advantage of all the engineered openings and light apertures. Instead of buying one of those chintzy HDPE project boxes and hacking out power supply openings and trying to align holes for LEDs, use the ones already there! The kind engineers of USR have already done the dirty work for you!
I hope this is not a repeat of someone else's contribution but you can use many of the later dial up modems as an answering machine; auto-dialer and even a phone call redirecting system. I was using my old Netcomm for this up until recently. I wrote code in "good-ole" Basic and I believe I could have made many more things happen. There was an application that logged calls and another that allowed you to silently dial up and bug a room. Coupled with a sensitive microhone I used this for a while to check if there were intruders in my house when I was away.
magic... i use arczip... google can sometimes take up to 10 seconds to load. the instructables home takes ~ 2 min 20 sec to load with all the pictures.
the firewall and other programs (like the OS) are best "auto updated" so they don't go unpretected long....but man can they take the time to download an install sometimes.
Bio:I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://en.wikipedia.org/wiki/Universal_asynchronous_receiver/transmitter
http://en.wikipedia.org/wiki/DTMF (there should be a generator to handle ATDT commands in the 56K)
. I have no idea how DSL and cable modems work other than they usually have an Ethernet port. :(
Yeah, but I don't have that....would need to buy it. :-)
Thanks for all the info...
Anyway, good luck.
. null modem (serial port to serial port)
I haven't :-)
