KWR1 V.1 + "The More Bands, the Better" Myth
The KWR1 (K’NEX War Ready gun #1 Version #1) V.1 came out of my idea to build an entirely “mod-able” slingshot sniper weapon that you could rely upon in any outdoor K’NEX war (hence the name). You could make this gun longer; you could make this gun shorter. You could add a nonadjustable stock; you could make the stock longer, you can do practically anything to this gun (other than change the mechanism and the handle position).
Features:
  • Good range: 60 ft. (1 band) – 100 ft. (5 bands, 45 degree angle)
  • Can shoot: Oodammo (1 band: 60 ft.), Large K’NEX wheel (5 bands: 30 ft.), Small K’NEX wheel (5 bands: over 80 ft.), Lego bricks (5 bands: 50 ft.), NERF darts (5 bands: 50 ft.), and size #117 bands as a RBG (30 – 40 ft.)
  • 10 point adjustable stock (see pictures 8 -11) with “Stock lock” (see pictures 13 - 15, 17)
  • Totally customizable
  • Safety (see pictures 15 - 16)
  • Cheek rest (see picture 9)
  • Not too piece consuming
Now, with all of that out of the way, I want to talk about ammo sizes and the “the more bands, the better” myth. So to do that, let’s look at the stats (shooting with three size #117 bands):
Red Connecter Ammunition:
No rod attached: 62 ft.
Green rod attached: 55 ft. 4 in.
White rod attached (oodammo): 42 ft.
Blue rod attached: 35 ft. 5 in.
Yellow rod attached: 40 - 45 ft.
Red rod attached: (got caught in the bands)
Grey rod attached: (got caught in the bands)
Grey Connecter Ammunition:
No rod attached: 64 ft. 9 in.
Green rod attached: 59ft. 4 in.
White rod attached: 50 ft.
Blue rod attached: (got caught in bands)
Yellow rod attached: 40 ft.
Red rod attached: (got caught in bands)
Grey rod attached: (got caught in bands)
As you can see, the larger the round got, the lower the range you would receive. I think that this is a direct proof that bigger bullets are not necessarily good ammunition. For example, the ZKAR uses yellow rods? Might it get better range if it shot blue rods? Now, admittedly, the instances may be different with different guns, but I highly doubt it.
Conclusion: Stick with ammo sizes between blue rods and white rods (including both the blue rod and the white rod).
Now I want to talk a little about the “the more bands, the better” myth.
I took the KWR1 out to my backyard, grabbed some oodammo (growing in our garden, mind you), and commenced shooting from a prone position. Then I got this idea… what if I was to shoot with only 1 band, and not all 5? So I started to do that, leaving the bullets where the fell after having been shot. Then I decided to go back to shooting with 5 bands, to see how much better the range would be. So I fired a couple rounds… and got no better range than I did when I shot with only 1 band. I did this a couple more times, and found it to be true.
There is a myth (myth = a traditional story) pervading instructables that you will always get better range with more bands. Now, it is my personal opinion that if a gun can’t get 50 ft. with two bands, it’s no good, but that is irrelevant.
Conclusion: More bands does not necessarily mean better range.
Now, I am not stating these subjects as fact, for that would seem arrogant and presumptuous, but I do believe they are, to some extent, true.
-The Red Book of Westmarch
1-10 of 25Next »
The Red Book of Westmarch (author) 3 years ago
V.2 Coming soon!
Red, I think you did a great job with this, and this is definitely accurate. More bands, after a certain point, don't add as much range as they did when you were putting the first bands on; it almost makes it seems like the range doesn't get better. It does by a tiny bit, but it takes a lot of bands to get significantly better than three to four bands.
I think that's pretty much what we've discovered as a result of all this testing. I salute all that weren't lazy like me and actually tested some stuff. :P
Thanks bro. I am glad that I meet your approval.
Ok then. >:? You're welcome, I guess.
Make sure to read both of the rackers comments as they are true mabye blunt but true and that stock mech is cool I will have to try that out
I read them both, but I find it hard to believe that 10 bands with give you any better range than 3 or 5...
it will, just decreasingly less each time
Hmmm...
It's true
Remember this doesn't apply to slingshots.
1-10 of 25Next »
