Keeping our troops in Iraq cool in the 104 degree weather
Any idea's of keeping our troops cool in Iraq? Temperature rises to 100's during the day. Seems our government only has more cumbersome vests with (the lightest) cooling motors of 6 pounds and from what I gather can only be used in a vehicle.
1-10 of 17Next »
gyromild10 years ago
I love this ible Hilsch Vortex Tube
And i think combining a miniature Hilsch vortex tube, with rubber air-sac inside the soles of soldier's boot could possibly work. The compressed air is generated by soldier's bodyweight pressing on the air-sac while walking.
The question is how effective is the tube if it has to rely on such a small source of pressurized air..
. It takes a lot of air to run a vortex cooler; much more than a "boot pump" will put out. As per the iBle - "(make sure you're running the tank around 100-150 PSI)" - it takes quite a bit of pressure, too. . They are real handy when you have a good source of compressed air (eg, under a sandblasting suit) or in areas where electricity is too dangerous.
On a more serious note, would it work to have a hollow necklace, filled with some kind of refrigerant, and a camelbak style pack to convert the gas to liquid and back? Would that be too expensive? Too big? Too heavy?
. It would work, but has a few problems. . All materials that I know of that would work (Freon, ammonia, CO2, N2, etc) are asphyxiants, so having it that close to the nose/mouth is not a good idea. Although the neck (and head) should be a very good place to remove heat; plenty of blood flow. . Any gas/liquid conversion system will take a lot of power, ie, weight, to run. . Noise reduction would not be insurmountable, but would add weight. . . It would probably be a valuable piece of gear on certain missions (when you could leave something else behind), but I don't think it would work for a battlefield soldier. . There are a lot of good systems out there (including your "necklace") that work well in special applications (usually where "low cost" power is available). An astronaut or pilot does not have to worry as much about carrying around an extra 20 pounds of mass as a foot soldier.
trebuchet0310 years ago
The best way would be to relocate them... To say their respective hometowns ;)
Fan + Helmet Like this storm trooper helmet - Make is solar powered and we'd have a green army o.0
So, an astronaut's space suit uses water, a pump, an undergarment with flexible hose, batteries and liquid oxygen (needed for breathing anyway). Of course, this makes one less mobile. But that's one solution and as mentioned, there are alternative gases.
So then there's systems like this. But again, heavy, bulky, limits mobility.
Really, the big problem is the large size of a suitable heat exchanger. Even when you do a liquid--gas phase change, the equipment is too bulky. If you've ever seen a photograph of an astronaut or cosmonaut carrying a box connected to their suit (on earth) -- that's the heat exchanger -- that's what holds the liquid gas :/
> the equipment is too bulky . At our current level of technology, that pretty well sums it up. Maybe "someday." Not sure there is _any_ way to get the size of the heat exchanger down - one can only get rid of so much heat when the ambient temp is 104degF. What would that make the deltaT - 20degF? 25? . How many Watts (or other units) does a person put out as body heat? My search skills don't seem to up to the task. I've seen some figures before, but no idea where. . . When I first saw the Storm Trooper helmet, I had to laugh, but then realized a mil-spec version of that would probably be pretty effective. Some very efficient motor/fan designs and compact batteries available nowadays.
Yes, there's always the someday scenario -- but hopefully, someday we won't have the need to cool off troops in Iraq :/
This seems to be a decent source for heat output.
Ice Cubes!!!!! Lots and Lots of Ice Cubes!!!!
jtobako10 years ago
Small canisters of liquid CO2 or nitrogen slowly releasing cold gas threw vents in their armor. Even if the gas temp is not cold, the dryness of it should help evaporate sweat.
. What about suffocation in an enclosed space? . You'll probably use 10 lb/hr of liquid or more (just guessing - anybody have an accurate figure?). That's a lot of weight to be toting around. . If you get shot through the cannister, you have a bullet wound AND frostbite.
1-10 of 17Next »
