loading
Knex Firepower Standard
Hello everyone I (like alot of my freinds) get tired of... oh why dont you just search "Knex gun" and look at the mini descriptions and read them all, or maybe most and think what alot have us geting tired of, Go ahead! see you in maybe a min or 2? just click back or whatever to return here! and continue from where you last read.
Welcome back! Do you see what what I'm talking about? well there are two things and if you did not notice these things feel free to look again!
And what is Sypran talking about? (drumroll) the Quotes "It's very powerful" "easy yet powerful knex gun" "gun shoots about 60-70 feet" "this is a very small gun but will fire about 50 feet" "A deadly knex gun" and that is just the first page! i could go on for hours (ok maybe a long time) of coppy and pasteing these quotes!
honestly i see to much "easy yet powerfuls" i cant realy tell what is powerful! so what do we do? well we take out time building maybe some and it turns to be not that great or it is great!, or we rush to see if KILLERK, Mepain, Extreme builder, Trainman2000 (i will always call him that >=D)You (aka mykhailo),Perfect duck,loosewire,Dsman19(i cant rember numbers) Oodalumps, am i forgeting anyone? (tell me if i am) has any new ideas/guns.
so what do we need to do? WE NEED A FIREPOWER STANDARD something simple like 1-20 and how to mesure it,
in earth science they clasify rocks hardnes by what they scratch (nail 2.5 glass 5.5 and so on) we need it something like paper peice, but not that for some guns have alot of power but cant peice due to low velocity and or dull non sharpened bullets.
also if you know anything about real guns the bigger the bullet, the more powerful =D but the smaller the bullet the higher peirce rateing (a 0mm would be the best peirce but little damage) so in other words the biger the bullet (45 cal example) the more stoping power it will have but less muzzle velocity (pierceing ability) wile the smaller (7mm) the knocking over/stoping power is anything to be desired, but it will have high muzzle velocity so peirce through more materials. yet with (if it was at all posible) a 0mm (or basicly nothingness) in theory could peirce through ANYTHING but would not stop the person or thing in any way
so the same pricable stands for knex notice the shotguns that shoot conectors (or killerks magnum with his amo) create a biger bang sound, they do more damage, but need more force to get all that mass through a paper wile the ones that shoot sharpened (like gorkem's) or greens can peirce paper with ease.
so not only will we need a firepower test but a peirce test.
peirce is easy enough its velocity and ammo size and a variable if it is sharpend and we have an instructable on how to determin bullet speed.
power is bullet size+ extentions (killerk's magnum ammo like) also a little velocity
but the system needs a ruberband standard to keep in mind no putting on more then the systems amount of ruber bands or size of ruber bands (i know people will do this anyway)
so what am i basicly saying in this topic? easy please people we need records of bullets speeds for sertain bullets with your guns it is easy since most of you seem to have digital cameras and there is an instructable about it. also we need to know a standard RB cause i dont know whats standard in the rest of the world besides USA and even then i dont know if its standard in the other states (they say americans like everything bigger and sadly sometimes it's true)
i have tested some guns out and lets say that stong yet easys from the first page so far are low... so maybe we need a test for difrent kinds of guns! i have seen rifles that fire like a medium pistol (for they are exept they have a longer barrel, bipod, stock, and scope) should these even be given a 6 out of 10 in every catagory? or should it be 2 outa 10 for rifles.
if lets say we got a standard of ruberbands to be 2 (not including trigger ruberbands) that where (makeing this up) a circumfrance of 3 inches, end of barrel being 2 feet away from camera
the adverage gun (all makeing up still) 25 feet with white shooting 1 foot per sec, does not dent an empty can.
bullet speed of 5 feet per second with a max range of 40 feet (acurate ranges ppl use mesuring tape) with a white bullet that dents and peirce through an empty can we can conclude that the gun has high peirce rate but beter then normal power rateing. so a 7/10 for peirce if best was a max of 60 ft bullet speed of 10 ft per sec and white rods then it could have scored higher.
one day when i search "knex gun" i want to see "my first Sniper!, it scored a 7/10 firepower and 8/10 pierce with 100ft range" cause then i can say that is a good gun I'm going to build!
1-10 of 37Next »
King_Banana8 years ago
OK MY BRAIN IS HURTING AFTER THE RATIOS AND STUFF
so heres a simple one
10-19= bad(*)
20-29=decent(**)
30-39=good(***)
40+= great(****)
anything ofer 100ft= amazing(*****)
Sypran (author)  King_Banana8 years ago
distance does not = power, take this for example
if you pull a bow half way and angle it it will go farther then a non angled full pull
yet the full pull is more powerful.
i know that but range is a good way to determine how good a gun is
heres another chart
peirces paper=*
styrofoam=**
cardboard=***
can on plastic bottle=****
wood of any kind=*****
I know this is a dead comment but could I get a 5* rating If it pieced 1/8 in balsa wood
TheXenk8 years ago
The problem is that almost no one has enough room inside to shoot a knex gun unless it's a total peice of ....you get the point. But, by going outside there are many other vaiables that effect how far a gun can shoot (eg. Wind direction/ speed, trees and other obstruction, etc.) Also power as in "can shoot through can" or "through 3 sheets of hard cardboard" can also be misconstrude in the way that range from the can is a main factor, point blank range is not always the most powerful range, often 1-3 inches away has exponentially higher power. What needs to happen is a tool be built (out of K'nex, what else?) that is not only easy to use but impossible to mess up, it should be able to give 100% accurate reading for all types of guns from the weakest to the most powerful. Also in terms of different types of ammo, rod size shouldn't matter( thats what she said) the only thing that should matter in terms of ammo is whether it is deer slug, rod, sligshot/ catapult rod(a rod with something the can grab the elastic), or other and specify what that is.
Range is all to often streched beyond reality by saying it can shoot 200 yards, when really it might be able to shoot 50 yards tops when pointed strait but 200 yards if it is pointed strait at the sky.
We need to bulid a target that you shoot from maybe 5 feet away and something mesures force, be it cardboard, or cans, or plywood, maybe even something that leaves a dent in it and you can mesure the depth of the dent to tell you how much force (eg. 1/2"=1, 1"=2, 1 1/2"=3, etc.)
Also one last idea if you would prefer to stick to range outside, is that you divide the range in feet, by the number of cardboard sheets(or other medium)the gun can shoot trough at point blank range (say it shoots 63 feet, and through 4 sheets of thick, corrugated cardboard the equation would be F= 63/4= 15.75, so your force rating would be 15.75)
These are only some ideas to get all of you thinking about a standard in K'nex gun power.
-TheXenk
Sypran (author)  TheXenk8 years ago
Nice job, i like the way you think
TheXenk Sypran8 years ago
Thanks man
Katarukito9 years ago
there should be categories for guns too, crap guns 1-5 feet , pistols 10-30 feet assault rifle and etc 50-80 sniper 100+
Sypran (author)  Katarukito9 years ago
crap guns lol (im actualy laughing) i have never seen a gun that fires only up to 5 feet but i gess stuff happens
Dutchj Sypran8 years ago
Most semi-auto's only fire that far. Mine goes further, but I guess it's not 100% semi-auto.
1-10 of 37Next »
