Knex Gun Triggers
It has come to my attention that there is some controversy surrounding Knex gun triggers. I know very little about Knex guns and have become extremely curious as to why this was. What is a block trigger and why is it inferior to other forms of triggers?
1-10 of 22Next »
chazman28 years ago
best triger yoy can get is defnetley the ak 47 triger it gives you up to 7 shotes no reloding thats bling at its best.
Mepain9 years ago
Block triggers are the strongest possible form of trigger, as well as most reliable. When I make a weapon that I intend to use in a K'nex war, I'll use a block trigger on the gun. KILLERK's pistol uses a block trigger. There are other reliable triggers, and if I'm making something just for fun, I'll use a different kind of trigger. These triggers are usually not nearly as reliable though. Not inferior, but immensely superior.
DJ Radio Mepain9 years ago
I think with today's knex technology, the true triggers are just as reliable as block triggers. The sear system has a lot of work to do though....
Mepain DJ Radio9 years ago
What you refer to as true triggers are still block triggers, as they still block the pin from the front.
DJ Radio Mepain8 years ago
that comment made me think you were referring to the true triggers as block triggers in your other comment above.
Well, true triggers are more realistic and more instinctive to pull, like you pull on a real gun, and almost all block triggers go on a simple tube and stick design, so there really isnt anything new from block triggers these days.......
He means that as long as the pin is blocked from the front, it's a block trigger. It's still a block trigger if it uses a true trigger mechanism.
I knew that....
what about block true triggers like jammy uses on his storms? i believe they are the best
all his knex guns (except 222) have true triggers, not block-trues. 222 is pseudo semi-auto
1-10 of 22Next »
