Knex Semi Auto
When you think about it, there is no possible way to make a good, strong and cool lookinig semi auto. Unless it has multiple lbarrels, then it Is impossible. Why Try then?
1-10 of 33Next »
Kinetic5 years ago
Hah!
Bartboy (author)  Kinetic5 years ago
Link me? Obviously I'm... inactive.
But it still kind of seems like the strength of the gun relies on either something weak, or the strength of your finger. Or multiple barrels/firing pins.
Dude, haha wow. Look at kinetics and my semi auto. Haha sorry but there is multiple ways to do so
Bartboy (author)  innovanna5 years ago
Looked at them, they're cool, but still not exactly very powerful. 40-60 feet?...
Perfect for an indoor K'nex war! Also, the video of the TSA-1 is disabled, and I'd like to watch it. As of now, I still feel like multiple barrels is the way to go. Well, multiple firing pins.
Yeah but that makes a gun huge. Even with a pin gun you will stil get the same range. To many people lie about their ranges. This is the most powerful SEMI AUTO. Not gun. And the tsa-1 isnt good at all. That was an idea gun. Me and kinetics kinnos are more advanced and more gun like. I personally dont like double barrels but everyone is different
I have a double-barrel rifle I made years ago, and it definitely gets more than 60'. Using darts I've been able to hit pop cans aiming straight down the sights from 50' away, and it definitely shoots way further.
I'd love to see someone build an easy to use semi auto like that...
Thats cool. Thats cool. Sharirs is really easy becuase it isnt hard to wind up the spool after every shot. Even though you already get 5 shot semi automaticly.
TheDunkis8 years ago
Well when it comes down to it the physics behind semi autos is using the constant strength of your finger to pull back the ram. I have an awesome idea though. It might not look the best but it will be beasty. The only problem is it probably won't be strong if you use a normal knex motor. Get like one or two motors and make a rig where they spin the tires relatively close to each other like so they are barely touching but make sure they are secure. Then make a pushing mech where the trigger pushes the ammo from the magazine through the tires. If it's spinning fast enough you should get some pretty good strength but it does require a good motor or two. I wonder if it's possible to make like a spinning firing pin of some sort. Then you make a cog with a rubber band wrapped around. Then you pull the trigger and each time you do the cog will spin and launch the firing pin. I'm not sure how strong this will be but it should be slightly stronger than most guns and something new.
IVE HAD THAT IDEA TOO LIKE A FLY WHEEL LIKE AS IN A NERFS RAYVENS MECH
DUDE!! I'VE HAD THAT IDEA FOR A YEAR LOL! Except it would've been more like a belt instead of a tire.
1-10 of 33Next »
