3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knife concealment??
OK, i was wondering about how to conceal a knife, and i remember listening to Nocturnal podcast by Scott Sigler, and one of the gangsters had a knife in his shoe. i was wondering if i could hide a knife in my shoe like this:
1. put the knife under that removable pad in the shoe.
2. cut a hole in the back of the shoe that looks like this:
|_ _ _ _ _ _ _|
dont mind the periods, they are just place markers.
3. tie a string (fishing line) to one of the holes in the back of the handle, run the line through the above hole in the back of the shoe.
4. drill a hole in a quarter and tie the string to the quarter, then stick it in your pocket. when you need the knife, grab the quarter from your pocket, lift your leg with the shoe and knife, then pull it out. the way you cut it, the flaps will open and the knife will slide out, but will stay closed all other times. could someone please make an instructable on this, or tell me if it would work by testing it out?
34 comments
Jan 24, 2010. 8:33 PMtestingthelimits says:
 1. The shoe will probably fray around the slot you cut into it.
2. That is a pretty long string you're attaching to the knife. You're going to have to pull it out, then reach down and actually grab the knife?
3. Use a washer, not a quarter.
I have comfortably carried a single edge razor in my shoe with a method similar to the one described above. (one of the small, thin, disposable ones, sometimes used for scraping paint off glass). It was pretty easy to get to while sitting down, (bend your leg back and reach through the slot into your shoe) and it came in handy for some utility stuff.
You have an interesting idea here, I think you should consider scrapping the quarter and string and just carrying a second knife somewhere else to access when you are standing up, leaving the shoe knife for when you are sitting down/tying your shoe...
Nov 27, 2011. 7:50 PMYou_Betcha says:
I carry a Knife with me every where i go, I found that an An ankle holster is very comfortable and easy to acces and conceal, some Shoulder harnesses are nice, but you must wear a Jacket over them to conceal them. I would recommend using an ankle holster, they allow you to carry almost any knife on you with out drawing suspicion.
Mar 1, 2010. 3:34 PMLoneWolf says:
Ummmmmm.......that's not a bad instructable, but do you really think a shoe is the best place to conceal any weapon? If, for some reason, you have the need to carry a CCW it should be in a place easy to reach, not like a shoe....it would take waaaaayyyyyyy to long to get a hold on.
Jun 9, 2010. 2:45 PMLoneWolf says:
BTW - If this knife is being concealed for self - defense purposes, it would need to be fixed blade and longer than four inches. Thus, it would be rather ridiculous to try to hide a knife large enough to be a weapon in a shoe.
Mar 1, 2010. 5:25 PMtestingthelimits says:
 Not a weapon. A knife. Shoe knife will never really be a good weapon. I carry razor blades for utility purposes (cutting zip ties, opening boxes/packages)
I wasn't actually looking for a place to hide a knife. I was looking for a place to carry a single edge utility razor. They are rather difficult to carry without a case of some sort and a shoe keeps it from cutting my clothes/hands/ flesh while providing a blade that I am unlikely to leave the house without.
Also, read my concluding paragraph, specifically the part where it says "you should consider.... carrying a second knife.... to access when standing up.... leave shoe knife for when hands are close to shoes." (paraphrased)
Mar 1, 2010. 5:41 PMLoneWolf says:
Oh, sorry. Usually when people use the word "concealment" they mean for defensive purposes.
Mar 1, 2010. 11:20 PMtestingthelimits says:
It was my bad, I tend to use words too literally sometimes.
Hiding a knife in your shoe for self defense is definitely not the best idea.
Using your shoe to hold an extra utility knife is a good (or at least viable) idea.
Mar 2, 2010. 10:37 AMLoneWolf says:
Yeah.........in that case then it's not a bad idea at all :)
Jan 14, 2009. 7:38 AMLoneWolf says:
(removed by author or community request)
Jan 20, 2009. 8:51 PMalex-sharetskiy says:
just don't be patting you knife every minute to check that it's still there
Jan 21, 2009. 6:17 AMLoneWolf says:
Yeah that would be pretty stupid
Jan 21, 2009. 6:55 AMalex-sharetskiy says:
that's what people do, and cops look for that
Jan 21, 2009. 7:12 AMLoneWolf says:
Yeah a lot of people when they have a knife and their nervous about something-being attacked or getting the knife by security will sub-concuisly touch the knife to kind of reassure themselves
Nov 29, 2008. 3:17 PMWeissensteinburg says:
First off, why do you need to conceal a knife? Second, the knife would be extremely uncomfortable to walk on. Third, why don't you test it and tell us if it would work? Grab a cheap pair of shoes from goodwill, or somewhere of the sort, and test it.
Nov 30, 2008. 7:05 AMLinuxH4x0r says:
Yeah, but you don't need to conceal it. I always carry mine clipped to the side of my pocket or on my belt.
Nov 30, 2008. 9:16 AMWeissensteinburg says:
Or he could just put it in his pocket.
Nov 30, 2008. 1:02 PMWeissensteinburg says:
If you're going to conceal it, you might as well do it somewhere easy to get to. pulling it out of your shoe isn't going to be very quick.
Nov 30, 2008. 1:56 PMWeissensteinburg says:
When you're about to fight, you don't always have time, or room to lift your foot and pull. Plus, do you want a string hanging down to get caught?
Nov 30, 2008. 3:50 PMLinuxH4x0r says:
Guess where the other guy's knee is going
Nov 30, 2008. 3:53 PMWeissensteinburg says:
You can't map out a fight. you never know how it's going to happen. With all the tumult, your best bet is to have your knife as ready as possible.
Nov 30, 2008. 10:32 AMKiteman says:
Firstly, a knife is only good for self defence if you have been trained in its use, and if you can get at it quickly. Since you are planning to conceal your weapon in an awkward place, it is clear you have not had the training. Secondly, in the UK it is an offence to carry a concealed weapon. The definition of "concealed weapon" is so broad and vague that even a newly-bought knitting needle, still in the packet, could be cause to receive a caution; a knife in a shoe could get you community service or a short spell inside.
Nov 30, 2008. 1:10 PMLithium Rain says:
A knitting needle?? That seems a little extreme...
Nov 30, 2008. 12:43 PMKentsOkay says:
You poor, poor weapon deprived Europeans... I mourn for thee...
Mar 9, 2010. 5:59 PMArano says:
no need to mourn, i am allowed to carry a longsword with me whenever i want... what would your police do when someone enters a mall with a sword? ;)
greeatings from germany
Nov 30, 2008. 1:14 PMKiteman says:
That's as may be, but violent crime, including gun-crime, is apparently on the decrease in the UK.
How many people do you know who have personally been the victim of violent crime? I only know two, and they were both with me when we got mugged by a bloke who was apparently high on something, and was armed with a cosh.
Ironically, we were walking home after watching the first Robocop film in the cinema.
Nov 30, 2008. 1:31 PMKentsOkay says:
How many victims I know? I'd say 3. How many prevented victims do to guns? 6 i do believe...
LOL, that's irony for you...
Nov 30, 2008. 1:52 PMKiteman says:
That's one attack I know of in 41 years, compared to your nine in less than half that time.
LOL, that's maths for you....
(If we'd had a gun between us, instead of three mildly surprised and dented teenagers, there would probably have been one dead one. I know which I would prefer.)
(The only European country with a constitutional right to bear arms and store loaded guns at home, Switzerland, is also the country with a gun-use murder rate, per capita, second only to the USA - seven times higher than the UK, double Germany and Italy)
Nov 30, 2008. 12:45 PMKentsOkay says:
Make an ankle sheath and pack it in your sock, just you have to wear pants.
Or get one of these:
http://www.bowenknife.com/
I've got the 3inch double edge, it is awesome...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
