Kriss Super V (Vector for you COD fans)
I've finally gotten around to finding my camera, and well, I figured I might as well put something up, considering I havent done that in a while.  What we have here is a Vector done around the tds slant design. This allowed for the closest and most realistic feel. (it may not look it in the picture but the slant does feel just right, even though its about 10 degrees off) the handle is quite comfortable and the stock is moderately sturdy. the magazine isn't finished yet but it will fire grey connectors with the little green pegs. the front handle is actually quite... poor and doesent support much weight at all. If anyone has ideas for that let me know. the underbarrel ( where the handle is) and the first 12 inches of the gun have rail support and I am pretty sure the reflex sights that worked with barrax's ACR would be compatible for now, at least until I make my own. Has a "creative" trigger that hasn't been tested so, "we shall see" The rear portion of the gun that isnt filled up (cuz I know its driving you all crazy) is so you can pull back the charging handle, which ends up making the gun shorter.  This is good because this vector is not only a vector, its a replica :) The gun only varries by about 1 inch from front to back and by about half an inch from top to bottom.  If anyone has any suggestions let me know.
Just linking to the new slideshow, it has the latest pictures:
https://www.instructables.com/id/Knex-Vector-Kriss-Super-V/
V 1.0 General frame with huge open area
V 2.0 The one thats not open, has a stronger foregrip and a black dot sight :), and the stock is epic
V 2.1 Added a trigger guard
1-10 of 29Next »
The point of a dot sight is so no matter your position relative to the sight, the dot always shows up, on the lens, on what the gun is pointed at like a laser pointer with infinite range.
osi (author)  mettaurlover7 years ago
Ok? That is practically impossible with a knex gun... save for if you put a real dot sight on the gun, which is relatively useless...
Actually, it's not useless. You just have an accurate sight.
ha.. yea I guess they are, but for a knex war... I just don't see anyone going out and spending that kind of money on a sight, for a gun, whose accuracy lies in its first 30 ft...
Seleziona7 years ago
mUcH bEtTeR!!!!
osi (author)  Seleziona7 years ago
Thanks, I think ima try and fix it up a bit more, make some attatchments, and start the instructable today
Seleziona osi7 years ago
Cooooool
Putting up a slideshow right now, I made the handle sturdier.  The slideshow will hopefully let more people see it before I post.
Okay, okay, sounds good....
Did you try the link I put in the forum? or did that not work (the link to the slideshow)
1-10 of 29Next »
