LED Strips
Hey everyone!
Ive been on this site for awhile, and find it simply amazing. And now I have a simple question for some electricians :)
Im OBSESSED with light, literally OBSESSED. the only bad thing, is I know NOTHING in electronics, but ive started learning and am trying to assemble a very simple led strip light with some conductive tape, and 12v power supply and about 16 leds. (yes i know there is a bar tutorial, but i need some explaning on a few parts.)
I want to just have 16 leds in a parallel or series, (prefer parallel) so it can be put on a very slim piece of wood/metal/sheet or wherever i place it. I tried using the ledcalculator, but it keeps telling me i would need a resistor for EACH led, and that would just defeat my set up being "small and simple"
So is there anyway to just have ONE resistor in the VERY beginning, to limit the current of 12v down to 3.5 to supply to all the 16 leds? Kinda like in my drawing (that is bad) Because i want the assembly to be as small as possible, and would like not to use one for every LED
And also, how many leds would i be able to drive in a parrallel with a 12v power supply?
Thnx so much in advance!
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
Visit Our Store »
Go Pro Today »
hope it helps!!!
First, we need to know the current output of the battery. If you don't know then that's okay!
Next, we need to know how much current each LED needs. Usually it's about 10mA minimum, and 30mA maximum (we'll use 25mA = .025A). Please confirm this before using the resistor value I'm going to give you.
Now, we use Ohm's law. Since the LEDs are in parallel, we add the current and keep the voltage the same. That means you have 3.5V of potential across the leds, so you need an (12V-3.5V) 8.5V drop and 16*.025A of current, or .4A. Ohm's law is V=I*R, so R = V/I, which is 8.5V/.4A OR appx 22 ohms.
It's going to be hard to find a resistor that small, but there's no harm in going anywhere from 22 ohms to 100 ohms, they'll still light nicely.
The short version: you need a resistor somewhere between 22 and 100 ohms that will go between +V and the positive strip of LEDs.
t3h, thnx a bunch for figuring that out, after reading all your replies I kinda understood it alot better, and thought of this:
http://s73.photobucket.com/albums/i226/mu0p/?action=view¤t=led.jpg
Would that work out, not having to use a resistor at all, or maybe a very small one at the end?
And could power up to like 100 leds like that? Like you said t3h?
Because, im trying to power as many rgb slow fading leds with just the conductive tape a 12v power supply and maybe some wire.
And here is the LED stats for the led im using
Items Symbol Absolute maximum Rating Unit
Power Dissipation PD 100 mW
Forward Current(DC) IF 30 mA
Peak Forward Current* IFP 100 mA
Reverse Voltage VR 5 V
Operation Temperature Topr <> -40 <>~ <>85 ?
Storage Temperature Tstg <> <>-10 <>~ <>100 ?
Lead Soldering Temperature Tsol Max.260°C for 5 sec Max.
(3mm from the base of the epoxy bulb)
*Pulse width?0.1msec duty?1/10
? Typical Electrical & Optical Characteristics ( Ta = 25?)
Items Symbol Condition Min. Typ. Max. Unit
Forward Voltage VF IF=20mA 3.00 / 3.80 V
Reverse Current IR VR=5V ? ? 10 uA
Dominant Wavelength ?D IF=20mA / / / nm?
Luminous Intensity IV IF=20mA 4000 / 6000 mcd
50% Power Angle ?? IF=20mA ? ±10 ? deg
again, thnx alot everyone!!
Are you expecting multiple "slow fade rgb" leds to change color in a synchronized fashion when connected like this? I don't have any experience at all with such LEDs, but I'd be VERY surprised if they stay synchronized at all . It'd be worth some experiments on a solderless breadboard before you start soldering things together!
http://ledcalculator.net
as this will cut the resistence in half
example --2-- 680 watTs in parallel
will be 320 ohms =( LED BURN OUT )
but 2 --680 in series =1360 oms
there is a formula to do watts but i dont know it
