3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED advice
so, i'm a pretty avid fan of our local roller derby team (HKRG BABY!), and i belong to a group of super fans who focus on doing a lot of weird crafting and costuming and other such insantiy for the bouts.
so, i'm wanting to make some pretty fancy signs for next year's derby season that will  light up. i've got some plans to use some EL wire/tape and the accompanying equipment but i've also got some other sign plans that would probably be cheaper/easier to make using LEDs instead.
so, basic premise is to have a sign that would be able to light up some cut out letters separately and sequentially. i know how to make the sign itself so that's not the issue, what i need is a method to cheaply and easily make the letters light up in sequence.
so it's a 3 letter sequence (let's use D O A as an example) that progresses at the normal speed that you would imagine a large group of people chanting a 3 letter call sign to go. so the D would lights up for a second or two, one-two second pause, O lights up for a second or two, one or two second pause, then the A for a second or two, lather rinse repeat.
i'm imagining that each group of LEDs for each letter would be wired in series, then each group would be wired to whatever circuit would be needed to make the lights cycle. i'm not sure exactly how many leds will be needed per letter, but maybe between 10-20 of them per segment?
i'm going to have several of these types of signs (all 3 syllable chants) so i'd like it to be something that's easy to repeat and not terribly expensive (i'm a derby nut, but there is a line where cost kind of gets stupid)
11 comments
Jan 20, 2012. 4:36 PMGoodhart says:
Well, here is an overly simplified hackneyed version :-)
Dec 3, 2011. 9:53 AMHonus says:
I'd use an Arduino and simply turn on each letter in timed sequence using a transistor (a TIP120 would work.)
So what you do is connect a transistor to a digital out pin (be sure to put a resistor between the output pin and the transistor) then set the output pin HIGH to turn on the letter, have a delay, then turn on the next output pin high, and so forth.
If you would like a schematic or a code sample just let me know.
Dec 5, 2011. 11:12 AMHonus says:
Yep- you got it. The advantage of a mosfet over a darlington transistor (TIP120) is less voltage drop- both will work just fine for your application. I always seem to have plenty of TIP120s on hand so that's what I use.
There's another transistor usage tutorial here-
http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads
Dec 5, 2011. 11:28 AMHonus says:
Either color LED would work just fine- the green will look more green than white LEDs behind green film but the white might be a bit brighter. The rechargeable battery would be the way to go- a small 9V transistor battery won't be able to provide enough current for all those LEDs.
Dec 5, 2011. 7:35 PMHonus says:
That would probably work just fine. The voltage will depend on how you wire up your LEDs.
Dec 2, 2011. 10:10 PMGoodhart says:
Ah, finally I can post again....now what was I going to put in here.....?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
