LED calculator
Is there an easy formula or an online calculator to figure out what type of resistor I would need to hook up to an LED to keep from blowing it? I know you can also have a string of LEDs and the more you use you won't need resistors. I'm just trying to figure out for different projects with different batteries, what the most efficient circuit would be. Also what does T1 3/4 mean? I noticed that on the 5mm LEDs. How does it differ from ones without a designation?
1-10 of 13Next »
Goodhart9 years ago
great thanks
You're welcome :-)
imarzouka9 years ago
Check out this calculator. It's nice and simple
http://ledcalculator.net
jasc imarzouka9 years ago
I love that calculator.
Sure ! It's called the "Ohm's law".
Calculating the value yourself will give you a much better understanding of electronics than using the online calculator. The maths required is quite trivial, and Ohm's law can be used in so many other situations. Cheers, Pat. Pending
CameronSS9 years ago
I was given this one.
Danny9 years ago
resistors have different values if you look at one you will notice bands of colour on it, you always read towards the gold band.
you could find a chart of it on the internet here
from that you could work out how many of which type of resistors you need for the LED'S you have
schorhr9 years ago
Use a search engine of your choice, and whoops:
http://www.google.com/search?q=resistor+LED+calculator
Try the first link.
1-10 of 13Next »
