Laptop's fingerprint reader, is it possible to reuse it on desktop?
the dead laptop is a HP Pavillion dv3 4010sl, the sensor is a Validity VFS301 (cdk1071_r04_hf) as written on the sensor itself.
if i remember correctly it was shown as a USB peripheral.
maybe is simple and it need just some resoldering to a USB cable,
the problem is that the flat cable connecting it to the motherboard has 6 pins/lines and my knowledge in electronics is quite limited...
I've found online what seems like a motherboard schematics (pg.48) and the vendor's sensor's manual.
Does Anyone knows if is possible, If yes how?
Picture of Laptop's fingerprint reader, is it possible to reuse it on desktop?
rthomas610 months ago
I just picked up the same (or a very similar) device and I'm looking to do the same thing.
From looking at that diagram, Pins 1&2 are ground, Pin 3 is 5V, pins 5 and 6 are data and pin 4 is 3.3V. USB doesn't normally require 3.3V but with this, there's no telling.
I think I'll try connecting this up to a Raspberry Pi since the 5V and 3.3V are readily available and if it's detected, it will show up in the system logs.
sellena2 years ago
hi, I have exactly your fingerprint reader. I would know if you had some good results and, if you can post your results.
Thank you
caitlinsdad4 years ago
You would need the drivers that would work on a regular PC so you do not need to hack a custom set of drivers which may have been proprietary to your laptop.. In terms of the wiring, the extra connection to the USB normal 4 or 5 lines was probably to the onboard BIOS 3v battery so it would be live when the power was turned off.
CladZo91 (author)  caitlinsdad4 years ago
thank you!! i already got drivers that works, i see so is it possible to undersand wich lines should be solder to an usb cable? i think the schematics can be helpful but i cannot read them...
You would probably want someone with real electronics knowledge to verify but you've got USB DATA positive(P) and USB DATA negative(N), +5V or VCC+, and downward pointing triangles as GND or ground. Look up the pinout on any USB plug wiring diagram, if there are 5 pins, one is not used. Dunno if you need any additional resistors or capacitors to buffer the connections. Good luck.
