Laser Tripwire Turned Off By Laser Pointer?
comments
Add Comment
I'd recommend starting with the Another Laser Tripwire Instructable. Since it already uses an Arduino to detect the trip laser it's almost trivial to add another sensor. You would need to add another photocell wired similarly to the one used to detect the laser tripwire and connect it to a different input pin. You could then add code to poll the new sensor to detect laser hits. When the new sensor detects that a laser is shining on it. the program would disable the alarm (and maybe light an led to indicate "safe") instead of sounding an alarm.
Of course this isn't the only way to go about solving the problem. You could build a new system with a different microcontroller or build the whole system using basic logic gates.
If you need any help with the circuit/code or want to go a different route don't hesitate to ask.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
