Logging In to Instructables
9
comments
Add Comment
When I'bles does a software update behind the scenes, quite often the page versions you have cached will be inconsistent with what the I'bles server is expecting to get back (e.g., some of the "hidden" script and cookie stuff).
By clearing everything out, you guarantee that you're getting fresh HTML, fresh JavaScript, and fresh cookies which are compatible with the I'bles backend code.
Some times I open many instructables in tabs, and when I go to see each, I found I must login previously to see all steps. Luckily, I must login only one time, after that only need reload the others instructables.
But this behavior is random, I don't discovered what is the cause.
because you have cleared recent history? And sometimes this may remove active logins so that may ask you to do that....another reason may be because you have added a new plugin? Or Installed a later version of the browser?
But the reason I think this happened is because of the instructables server shutdown! The same thing happens to me! I used google chrome and after the instructables server shutdown and after the server came back up I still had the same problem! The server was up and everything was fine but the problem was still there so then I downloaded and installed firefox and firefox was able to save my passwords quite easily so now I am using firefox and everything works fine!
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
