Logon to ANY SYSTEM
Any computer you have access to the 'console' or CPU you can logon and see all the files...without passwords.
Let's address each level of security:
A) BIOS passwords
-Remove small battery from Motherboard and wait a few (10 min) for the capacitors to drain (unplug CPU). Then reboot. During reboot or at BIOS Password screen find BIOS make/version (Phoenix/AMI etc) and download a "Flash" BIOS update to USB or floppy.
-Use floppy to flash BIOS and bypass, modify BOOT path to add USB
-No floppy drive? boot from CD/DVD (ISO image...see instructables)
B) Login/Password:
Never hack what you can access. Boot from USB/CD-ROM and load your OWN OS from these devices. Login to your OS and "mount" the systems root disc, C: drive or other partitions.
Browse all their files....
C) Encrypted files (EFS)
Easy ! see http://support.microsoft.com/kb/255742/en-us and backup their private key, run EFSinfo.exe and set your NEW OS to the same Workgroup or Domain as the target. Then browse the files.
Any ideas protection or passwords that can block this?
D) Linux/UNIX is secure!
UNIX & linux systems simply change their Init levels to boot as root recovery (standalone/Admin/Single User = init 1) recovery console allows access to Boot options, load CD/USB OS boot and mount original file systems. Browse or add login to /etc/password and login or telnet/VNC/SSH etc...
Done
Protect your console! Lock & Block all USB, CD & DVD access.
Use dongle or hardware key!
Use NON-OS based encryption and PGP or DES standards!
good luck
Picture of Logon to ANY SYSTEM
1-10 of 12Next »
fwjs288 years ago
you can even poison the BIOS so that it collects passwords discretely and many other things...and it is impossible to detect...
erckgillis (author) 10 years ago
Yes many "back doors" are published...but alas a battery removal and reset (look for jumpers on CPU motherboard) will reliably work. Flash a ROM and you'll get guaranteed results! Drive the Librarians nuts when, hours after I walk away the PC is running Linux (DSL/Knoppix) and they have no idea....? What I need is a USB stick and USB hub in one so I can plug my boot USB in and the keyboard/mouse at the same time...like the Yego sticks I found online fo $20.
:-D
lemonie yourcat8 years ago
The last time the author posted anything was May 2008: he's gone. L
in windows, if you boot in safe mode the admin account is usually left wide open.
ll.1310 years ago
Woah! there's easier ways to get past a BIOS password!
http://www.computerhope.com/issues/ch000451.htm
http://www.uktsupport.co.uk/reference/biosp.htm
That's just two there are heaps more websites with the other codes.
erckgillis (author)  ll.139 years ago
I have a new technique with my bluetooth foldable keyboard and dongle... hehe..
"sniffing" bluetooth signals? =)
Naw, Any "locked" system i.e. missing keybaord & mouse in a "kiosk' mode like a Mall or Library can be had via a usb dongle..."dongle" is a small device plugged into a USB/Serial or Keybard port that connect devices wirelessly via BT. then sit back and use your Palm or BT enabled protable keyboard to escape kiosk modes, logon or use other techniques here to access a 'locked' system with your new keyboard/mouse. E
Once my friends went back to Windows while fighting to get the cursor to their control using the touch screen.I touched the "Back to menu" button before they did that though.
1-10 of 12Next »
