Longest Comment on Instructables (Possibly)
The longest comment on this site is one by Guardian Fox on the "What survival tools should I keep in my dorm room tool box?" If anyone can find a longer one, please PM me the link.
Keep in mind, he typed this with his own fingers, not by holding down the paste command for a day. If that's what you want, then go to http://www.instructables.com/community/the_forum_for_spam/
Source: Guardian Fox
For the dorm room, you only need a few tools. You're not going to be renovating, and you're not going to be doing much woodworking. You aren't allowed to do anything at all to the room beyond hanging pictures (if that), and most dorms forbid power-tools in the rooms no matter what you're use them for.
Here's my take on what you'll need for the dorm. I've included a lot of things that seem unnecessary, and you can probably live without some of it... but the kit will get you through nearly any problems you'll encounter at school or in an apartment:
-At least one decent multi-bit screwdriver. Look for something with a comfortable grip and sturdy construction. Avoid gimmicks like built in flashlights. I recommend the Piquiq brand which comes in a few different sizes and can be found in many hardware stores in North America. You can usually get their three-piece set for less than $20.
-A set of jeweler's screwdrivers. Get a cheap set because these little things WILL get lost. Look for something with at least a few unusual bits as well as the usuals. Get a 30ish-piece set for less than $20. Most handy if you've got a thing for messing with your electronics, but also great for changing a watch battery, fixing glasses, etc.
-A basic hammer. Nothing fancy needed here, and I've always preferred an ordinary wooden-handled hammer anyway. Go for a smaller hammer if you only plan on hanging pictures, get a regular-sized hammer if you plan on using it to do real work later on. Stanley is a good brand with decent prices, but there are lots of good budget-priced hammers out there. Drop by a hardware store and pick one that feels good in your hand. Less than $20 for a brand name. $10 or less for a bargain hammer. Make sure the head of the hammer is securely attached to the handle, no matter what brand you pick but a little tiny wiggle is ok. Hang a picture or tap a few finishing nails into a small project. Very handy, even when you use it wrong.
-Two utility knives with snap-off blades. One with the small size, and the other with the larger size. There are hundreds of brands of these on the market, and a lot of them are junk so spring for an Olfa (the best i.m.o.) if you can find it. Richard is a decent low-cost brand which is often found in paint stores. Again, avoid gimmicks. The most important thing you need to know is if the locking mechanism works well or not, as a utility knife can become dangerous if the blade is going to slide around while you're using it. Good knives can be around $10-20 each. Cheap, "disposable" knives can be found for less than a dollar, but be sure to buy something that seems sturdy. Add a self-healing cutting mat from the dollar store, and while you're there get a metal ruler for cutting straight lines. Smaller utility knives are good for light-duty applications like trimming photographs or opening packages. Larger utility knives are good for harder work like cutting lots of cardboard
-A measuring tape. You probably already have a ruler for school, but a measuring tape is much more useful for around the house. Get a 16' tape for good versatility. Choose one that has a sturdy housing and a tape that slides in and out easily. Bennett is a good budget brand you can find for less than $10 and I recommend theirs over any of the name-brand tapes out there. If you can't find that brand, go to the building supplies store and ask what brand the clerks and outside staff use around the shop. You could skip this one during college, but you'll need it one day and it's the kind of thing you can make uses for.
-Pliers. For around the house and crafting I find a pair of long-nose pliers more handy than a pair of linesman's pliers, but both tools have their place. Locking pliers (aka vice grips) are also super-handy. Get one or a set, but avoid the bargain brands. Look to spend at least $7 each for basic pliers, and at least $12 for a good pair of locking pliers.
-An adjustable wrench (aka thumb-wrench). Pick a smaller-sized model for your toolbox. Most of the nuts and bolts in the house will be small anyway. Go for something that opens up to 1" or 1 1/2" Brand isn't an issue, but make sure it operates smoothly and won't jam or work loose. Spend less than $10.
-Scissors. A usable, general purpose pair of scissors can be found at the dollar stores or in an office supply store. Make sure they open and close smoothly and that the blades don't wiggle. Look for one with a metal screw at the pivot so you can tighten it if it works loose. If you're using it routinely for cutting fabric or any other specific task, spend some extra money and get the right kind for the job or at least a good pair of general purpose ones. Less than $5 for cheap ones, $20+ for quality ones.
-Sewing notions; A pack of needles, a roll of white thread, a roll of black thread, and a roll of transparent thread, a few safety pins and any spare buttons you find. That should get you through any wardrobe fixes you may need. Each item in the kit should be a dollar or less, and you can save money by starting with a pre-made kit from a dollar store and adding a few of your own extras. Also highly recommended is this, http://www.dealextreme.com/details.dx/sku.1352 , but keep in mind it is cheap for a reason and needs constant attention.
-A soldering iron if it's allowed in your room, and only if you're working with or fixing electronics or jewelry. Get a scrap piece of plywood or something to use as a work surface. $15 for a basic 30w iron. Another $10 for a safer stand.
-A toolbox that holds everything. I like the ones that double as a step-stool, which you can find for $20-$30 if you look hard enough (mastercraft and rubbermaid brands). You might like something different, but small plastic toolboxes and even small plain steel ones are all quite cheap so go look and see what you like. You can even use your imagination and just use a plastic tote, a tacklebox, a backpack/messenger bag, shoebox, etc. Just pack your tools in it neatly and avoid putting the heavy or sharp ones on top of the ones that might break.
-A plunger. If your dorm room has a bathroom, this is a must even if you never have to use it. It's an insurance policy against one hell of a mess. $10-$15.
Anyway, that's all I can think of for tools. Craftier folks need more gear, and less DIY-prone folks need less. Use your best judgment and buy only what you can afford and might actually use. Pick up a few fasteners and adhesives too, usually as needed. Here's what you should probably keep on hand.
-A package of assorted picture-hangers and hooks (if hanging pictures is allowed in your dorm). Buy a pack at the dollar store. A few extra finishing nails and small screws would be a good addition to this as well.
-Thumbtacks. Buy a pack at the dollar store or office supply store.
-Scotch tape, packing tape, duct tape (or Gorilla tape).
-Twist ties. Get a bunch from a pack of trash bags.
-A package of superglue. Rather than one large tube, get the pack with several tiny tubes so you don't lose your entire supply when one dries up.
-Craft wire. Use it wherever you might use a twist tie, but also can be bent into whatever shape you need to become a tool or a piece of art. Dollar stores carry rolls of it often at 2/$1
20
comments
Add Comment
It doubles as a "Magic Eye" puzzle, try it!
This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes!
..This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes! This has got to be the longest small text comment. Ironic seeing as it is on a thread relating to the longest Instructables comment. This is a contest, do I win a prize? Please tell me I win a prize! I love prizes!
Also, LEPRECHAUNS!
Here's my take on what you'll need for the dorm. I've included a lot of things that seem unnecessary, and you can probably live without some of it... but the kit will get you through nearly any problems you'll encounter at school or in an apartment:
-At least one decent multi-bit screwdriver. Look for something with a comfortable grip and sturdy construction. Avoid gimmicks like built in flashlights. I recommend the Piquiq brand which comes in a few different sizes and can be found in many hardware stores in North America. You can usually get their three-piece set for less than $20.
-A set of jeweler's screwdrivers. Get a cheap set because these little things WILL get lost. Look for something with at least a few unusual bits as well as the usuals. Get a 30ish-piece set for less than $20. Most handy if you've got a thing for messing with your electronics, but also great for changing a watch battery, fixing glasses, etc.
-A basic hammer. Nothing fancy needed here, and I've always preferred an ordinary wooden-handled hammer anyway. Go for a smaller hammer if you only plan on hanging pictures, get a regular-sized hammer if you plan on using it to do real work later on. Stanley is a good brand with decent prices, but there are lots of good budget-priced hammers out there. Drop by a hardware store and pick one that feels good in your hand. Less than $20 for a brand name. $10 or less for a bargain hammer. Make sure the head of the hammer is securely attached to the handle, no matter what brand you pick but a little tiny wiggle is ok. Hang a picture or tap a few finishing nails into a small project. Very handy, even when you use it wrong.
-Two utility knives with snap-off blades. One with the small size, and the other with the larger size. There are hundreds of brands of these on the market, and a lot of them are junk so spring for an Olfa (the best i.m.o.) if you can find it. Richard is a decent low-cost brand which is often found in paint stores. Again, avoid gimmicks. The most important thing you need to know is if the locking mechanism works well or not, as a utility knife can become dangerous if the blade is going to slide around while you're using it. Good knives can be around $10-20 each. Cheap, "disposable" knives can be found for less than a dollar, but be sure to buy something that seems sturdy. Add a self-healing cutting mat from the dollar store, and while you're there get a metal ruler for cutting straight lines. Smaller utility knives are good for light-duty applications like trimming photographs or opening packages. Larger utility knives are good for harder work like cutting lots of cardboard
-A measuring tape. You probably already have a ruler for school, but a measuring tape is much more useful for around the house. Get a 16' tape for good versatility. Choose one that has a sturdy housing and a tape that slides in and out easily. Bennett is a good budget brand you can find for less than $10 and I recommend theirs over any of the name-brand tapes out there. If you can't find that brand, go to the building supplies store and ask what brand the clerks and outside staff use around the shop. You could skip this one during college, but you'll need it one day and it's the kind of thing you can make uses for.
-Pliers. For around the house and crafting I find a pair of long-nose pliers more handy than a pair of linesman's pliers, but both tools have their place. Locking pliers (aka vice grips) are also super-handy. Get one or a set, but avoid the bargain brands. Look to spend at least $7 each for basic pliers, and at least $12 for a good pair of locking pliers.
-An adjustable wrench (aka thumb-wrench). Pick a smaller-sized model for your toolbox. Most of the nuts and bolts in the house will be small anyway. Go for something that opens up to 1" or 1 1/2" Brand isn't an issue, but make sure it operates smoothly and won't jam or work loose. Spend less than $10.
-Scissors. A usable, general purpose pair of scissors can be found at the dollar stores or in an office supply store. Make sure they open and close smoothly and that the blades don't wiggle. Look for one with a metal screw at the pivot so you can tighten it if it works loose. If you're using it routinely for cutting fabric or any other specific task, spend some extra money and get the right kind for the job or at least a good pair of general purpose ones. Less than $5 for cheap ones, $20+ for quality ones.
-Sewing notions; A pack of needles, a roll of white thread, a roll of black thread, and a roll of transparent thread, a few safety pins and any spare buttons you find. That should get you through any wardrobe fixes you may need. Each item in the kit should be a dollar or less, and you can save money by starting with a pre-made kit from a dollar store and adding a few of your own extras. Also highly recommended is this, http://www.dealextreme.com/details.dx/sku.1352 , but keep in mind it is cheap for a reason and needs constant attention.
-A soldering iron if it's allowed in your room, and only if you're working with or fixing electronics or jewelry. Get a scrap piece of plywood or something to use as a work surface. $15 for a basic 30w iron. Another $10 for a safer stand.
-A toolbox that holds everything. I like the ones that double as a step-stool, which you can find for $20-$30 if you look hard enough (mastercraft and rubbermaid brands). You might like something different, but small plastic toolboxes and even small plain steel ones are all quite cheap so go look and see what you like. You can even use your imagination and just use a plastic tote, a tacklebox, a backpack/messenger bag, shoebox, etc. Just pack your tools in it neatly and avoid putting the heavy or sharp ones on top of the ones that might break.
-A plunger. If your dorm room has a bathroom, this is a must even if you never have to use it. It's an insurance policy against one hell of a mess. $10-$15.
Anyway, that's all I can think of for tools. Craftier folks need more gear, and less DIY-prone folks need less. Use your best judgment and buy only what you can afford and might actually use. Pick up a few fasteners and adhesives too, usually as needed. Here's what you should probably keep on hand.
-A package of assorted picture-hangers and hooks (if hanging pictures is allowed in your dorm). Buy a pack at the dollar store. A few extra finishing nails and small screws would be a good addition to this as well.
-Thumbtacks. Buy a pack at the dollar store or office supply store.
-Scotch tape, packing tape, duct tape (or Gorilla tape).
-Twist ties. Get a bunch from a pack of trash bags.
-A package of superglue. Rather than one large tube, get the pack with several tiny tubes so you don't lose your entire supply when one dries up.
-Craft wire. Use it wherever you might use a twist tie, but also can be bent into whatever shape you need to become a tool or a piece of art. Dollar stores carry rolls of it often at 2/$1'
I win. But anyway, is there a way to find the longest comment if this isn't it by going to comments then recent and go to the last page?
You cant win on a technicality
Well it depends if the rules say you can or not. I'll just assume i can't with your rules.
Well, someone obivously did.
I know I dont!
Same here.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
