Looking for some good info on CNCs
Hey guys, Ive been looking at a lot of the CNC projects and I really want to try something of my own.
I could really use some good reading material on basics of building a CNC.
I would like to build a 2 axis CNC for laser etching/cutting first and work my way up to a 3D mill.
I could really use more info on the following:
-How to properly use screw threads (bearings, mounting, etc)
-Limiting factors to CNC strength (I would like to mill Aluminum eventually, what will I need? Just a higher torque stepper motor?)
-Other important tips in designing and building my own.
Feel free to just post links and ill look more into it. Ive seen a couple decent sites but a few of them werent free.
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
Visit Our Store »
Go Pro Today »
If you want strength then you'll want to have 2 steppers for your X and Y axis and 2 screw threads. This gives you a sturdier rig and allows you work with heavier materials if the steppers can support it.
The limiting factors of how strong the CNC is will be how powerful the motors are that your using and how sturdy the frame is. You can have the best of the best steppers running everything but if you start to bear down into a material and your frame or screw shafts buckle it won't get the job done. The stronger your overall frame is the more accurate you'll be. You don't want any wiggle room in any of the axis.
Just keep looking at what other people have made and the methods they used to make it. Also look at the way consumer and industrial grade CNC are set up. Copy there frame work.
