COMMUNITY : FORUMS : OFFBEAT
Lots of Drinking straws
My mom threw away a bag of drinking straws (about 200-300 left) , they are wraped in paper, any ideas on what to do with them for a new Instructable or something. PS: took the picture last year and had nothing to do with it
Goodhart says: May 29, 2012. 5:31 PM
with a balloon, one can make a "make shift voice box" with a modified drinking straw.
meetscottewart01 says: May 14, 2012. 8:28 PM
cute pic!
flashj says: Sep 24, 2011. 6:09 AM
I was thinking about some sort of wind turbine or other powered device. I have about 50 bendy straws. They are kinda a use one and throw away thing, so I have a steady supply coming in. Arranged in a pinwheel so that one is always into the wind like a paddleboat wheel? Just off the top of my head. Not sue what to do with the air when it gets to the center... Maybe glue them to a paper plate and sandwich a bunch on a central pole. Thinking about stuffing them into the end of a pipe splayed out in all directions see what comes out the other end. With water you might try a variation of a drip irrigator? Just my 2 cents and 30 seconds.
whatsisface says: Oct 21, 2007. 3:42 AM
You could try taping them all together, and seeing how faraway from the can you can drink a can of Cola from.
The_DonuT in reply to whatsisfaceJan 25, 2011. 6:15 AM
I would use water , it could be messy! :D
Kiteman says: Oct 21, 2007. 4:55 AM
Build stuff.
Bridges, towers, cranes, figures.
Make several hundred small kites.
Try recreating a Jansen Strandbeest in miniature:
Basically, be creative
dombeef in reply to KitemanApr 5, 2010. 7:42 PM
 That would be very cool to see a mini strandbeest!! (I see an instructable coming on...)
dombeef in reply to dombeefApr 5, 2010. 7:44 PM
 Here is a leg picture i found
NachoMahma in reply to KitemanOct 21, 2007. 3:29 PM
. What is the motive force for this thing? Are those windmills on the ends?
NachoMahma in reply to NachoMahmaOct 22, 2007. 2:05 AM
. OK. Thanks. Looked at a few of the videos and he has some very interesting stuff. If nothing else, they look tres kewl. :)
jtobako in reply to NachoMahmaOct 21, 2007. 4:42 PM
Wind on the bulk of the machine. Otherwise, you just push (or pull) it along. It's a neat idea, but it needs all those legs so that the motion is smooth enough that the wind will move it on it's own.
Kiteman in reply to NachoMahmaOct 21, 2007. 4:34 PM
Yes - the idea is that they roam the beaches under "natural" power (the name means "beach animal"). Others have wings flapped by the wind, and some actually store wind energy as pressurised air in soda bottles, sort of pressure-capacitors - when they're full, the beast takes a couple of steps. Check YouTube for "Theo Jansen" and you'll see loads of copies of videos of his stuff, plus a few people making their own.
Goodhart in reply to KitemanOct 21, 2007. 3:21 PM
Cool !
Goodhart says: Oct 22, 2007. 12:31 PM
if you have a few that are slightly smaller in diameter than the others, you could make miniature pumps with them.
killerk2 says: Oct 20, 2007. 4:51 PM
you can put homemade explosives in them and blow them to oblivion
Goodhart in reply to killerk2Oct 21, 2007. 9:36 PM
one could make an "underwater fuse" casing with them.
killerk2 in reply to GoodhartOct 22, 2007. 12:17 PM
lol or a really long barreled air gun
astrozombies138 says: Oct 21, 2007. 10:03 PM
take 2 straws close one end on each one fill 1 with baking soda and 1 about 3/4 of the way with vinegar,and the other with some baking soda, put a piece of toilet paper ontop of the vinegar straw and then put the baking soda one on that, once you turn it upside down point it at somone and maybe it iwll shoot?
Kiteman in reply to astrozombies138Oct 22, 2007. 1:55 AM
Hmmm....
Heat seal one end of the straw (soldering iron? Curling tongs?)
Pour in a teaspoon of baking powder and tap it all the way down to the sealed end.
Bend the straw into a V, sealing the powder in the sealed end.
Add vinegar to the open end and seal the open end.
Wrap an elastic band around the folded straw to keep it folded and keep the vinegar & baking powder apart.
Later...
Remove the band and slip the straw somewhere awkward - into a friend's pocket, through the vent of a locker, through a keyhole into a locked room.
Maybe scatter a handful across the lunchroom floor.
Retreat.
jtobako says: Oct 21, 2007. 4:54 PM
Vents for lost foam metal casting. Bushings for simple robotics, vandergraph generator or mouse-trap car. initial stage for a blow-pipe (old soldering torch). Pan-pipes. bubble pipe. Plastic for casting. Sell them as pea-shooters-including hygenic safty wrap and ammo. Structural tubing for small airplanes (glider, rubber-band power or RC). Two types of fuse-pipe (plastic and paper). Make tiny one-shot rockets out of the paper wrap, using the straw as the launcher (don't take the paper off-it's very difficult to 're-load'). home-made pixie sticks. Use heat to re-shape the plastic into thiner or wider forms. make tiny baking powder submarines. Fill the local pool with them and watch them bob up and down... um, use them to drink with?
Punkguyta says: Oct 20, 2007. 8:04 PM
I think we need to put a registration filter to deny access to kids younger than 16.
jtobako in reply to PunkguytaOct 21, 2007. 4:43 PM
That would have included you...
Weissensteinburg in reply to PunkguytaOct 21, 2007. 11:20 AM
The rules are you must be 13...which he is. Plenty of people ask about what to do with stuff that they've got. For instance, there's one particular member who often posts asking for help about how to best use his stereo system.
Punkguyta in reply to WeissensteinburgOct 21, 2007. 6:01 PM
I already know what to best use my stereo for, MUSIC DUH!
Weissensteinburg in reply to PunkguytaOct 21, 2007. 6:12 PM
How, not what.
NachoMahma in reply to WeissensteinburgOct 21, 2007. 12:01 PM
. Zing!
Punkguyta in reply to NachoMahmaOct 21, 2007. 6:02 PM
Zing yourself.
TheCheese9921 (author) in reply to PunkguytaOct 21, 2007. 9:55 AM
tell the admins then
Patrik in reply to PunkguytaOct 21, 2007. 3:29 AM
Give the guy a break - it *is* an interesting question...
First thing which comes to mind is building some plastic plumbing. stick one straw into the end of the next. Wrap with tape. See how far you can get (200-300 straws = 200-300 feet?) run your plumbing from the upstairs sink down to the kitchen and see if you can get water through without any leaks.
Are these "bendy" straws? I imagine you could make a cool tree sculpture with linked straws. If you have 200 straws, link them together into 40 "long straws" of 5. Bundle them all together with a rubber band for the "trunk" of the tree (you can save some of the inside straws by replacing them with a cylinder in the trunk). At the second bend, bend half the straws in one direction, the other half in the opposite direction. Now you have two main branches - bunch each together with another rubber band. At the next bend, split the branch again into two or three smaller ones. Keep doing this until you've split all the straws into separate "twigs". If you want to get extra-fancy, alter the length of each straw to make the bends line up well. Try to make it organic looking.
TheCheese9921 (author) in reply to PatrikOct 21, 2007. 9:50 AM
no there just plain clear straws no bendy
chooseausername in reply to TheCheese9921Oct 21, 2007. 11:37 AM
A mini pipe organ ?
Kiteman in reply to chooseausernameOct 21, 2007. 3:15 PM
Make hundreds of straw oboes (you'd get about three per straw) and dish them out to all the students at the school gates on the way in...
TheCheese9921 (author) in reply to KitemanOct 21, 2007. 3:20 PM
that would be funny but I'm a freshmen, and no one would do it anyway :(
Kiteman in reply to TheCheese9921Oct 21, 2007. 4:37 PM
I once did that in McDonalds - there were a load of kids in when I made one for my young son. They were cheeky enough to ask me to make oboes for them as well, so I made them for every kid in the group.
I slyly took the oboe off my own boy, then sat back and watched as, after about two minutes of loud tooting, the McClones threw the gang of kids out for being too rowdy... :-D
astrozombies138 in reply to PunkguytaOct 20, 2007. 11:12 PM
hey im 14 n ive been reasonable with what i post
Goodhart says: Oct 21, 2007. 3:27 PM
I agree with Kiteman, for a test once, I had to come up with as many ways to use a pencil as possible in 2 minutes: most in my class came up 3 or 4, but if you think outside the box, you can do most anything. Everything from : cut into thirds or fourths, and then slit, they can be wire organizers (tracks) for thin wires; make pencil "covers/protectors"; to costume enhancements...tis only limited by your imagination.
astrozombies138 says: Oct 21, 2007. 11:59 AM
how about the worlds most elobarate drinking straw. make it fancy
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
