Low AC to DC conversion
Hi, I'm looking for simple way to convert a low AC into a usable DC, of say 4 - 5 volts for charging batteries. I recently saw one discussed online, specced at costing about a quarter, but couldn't find a way to do it, or a way to purchase something like that. Thanks!
1-10 of 19Next »
FC776 years ago
Hi , just say you had 20 volts , 55amp ac , and wanted to convert it to dc , what type of bridge diode rectifier would you use ? Would you use one close to the stated power or would you use one that is say 150amp and 1000volts for instance , does it make a difference ? Also Does the phase of the rectifier matter ? Thanks !
guyfrom7up10 years ago
are you talking about the windbelt project? What I'm working on is using a low voltage drop shottky full wave bridge rectifier hooked up to a filtering capacitor hooked up to a max1709 chip (my favorite boost chip ever!)
fafnir665 (author)  guyfrom7up10 years ago
Yes! Do you have a diagram for this?
well, I'm to lazy to draw up a diagram, but I'll walk you through it.
a full-wave bridge rectifier is 4 diodes that when correctly connected together convertes AC into DC (google it). The out put of this is basically if you were to take the AC wave and flip it all onto one side. Diodes have a volotage drop across it, which means you lose voltage. For this project you want as many volts as possiable, so you use low voltage-drop schottky diodes for the bridge rectifier. The output of the bridge rectifier is really ripply, so all you need is a capacitor (maybe around 100-1000uF) at the output so that it smooths out the ripples. That filtered voltage then will pass through a DC to DC converter.
Here's the one that I'm going to be using: http://datasheets.maxim-ic.com/en/ds/MAX1709.pdf
If you most of it then it will be easy to pick out the parts. A nice schematic is on page 8 where you just have to fill out some values.
I might post a diagram later
Ah, and the boost chip is has a pinout too sweet. Thanks!
make sure you read the datasheet first! Remember, reading for about 10 minutes could save you 50% or more on electronics parts I have never seen the geico commercial ever
The thing is that i want to use for space aplication not any normal application so want to avoid boosters . So is there any technioque to convert low voltage high frequency AC to propotionate DC. ketan.isro@gmail.com
Goodhart10 years ago
Define "low AC". If you are a few volts above your target, a bridge rectifier and power regulator (and a few capacitors) would fit the bill.
hey i need a help about conversion of a low voltage (<1V) Ac at frequency of 1 MHz to linear DC level can u help!!!!!!!!
As suggested, a bridge mde with Schottky diodes instead of silicon or germanium diodes might work. Schottky diodes are useful in switch-mode power converters; the high speed of the diode means that the circuit can operate at frequencies in the range 200 kHz to 2 MHz, allowing the use of small inductors and capacitors with greater efficiency than would be possible with other diode types. Small-area Schottky diodes are the heart of RF detectors and mixers, which often operate up to 5 GHz.
1-10 of 19Next »
