Low Cost Low Tech Ozone Bubbler
I'm thinking aquarium pump to begin with.
9
comments
Add Comment
It's more UV based then anything else, but UV light does produce Ozone, so... it may not be completely inaccurate to say it's sterilized by Ozone to a certain degree, but it's more likely a combination of the anaerobic atmosphere of the bottle coupled with the UV light (an atmosphere which doesn't usually exist in nature).
PET bottles do have one serious problem when used as sterilization though: PET can leech plasticizers into water when exposed to UV light. It's part of the whole Bisphenol A debate that's going atm.
As for the Safety of Ozone, it's safer then chlorine gas, which may not be saying a whole lot. It does react quickly with many organic molecules so it's not like you're introducing a toxic pollutant that can't be easily removed.
Finally, rather then a straight Ozonation process, why not use Titanium Dioxide?
It's been shown to produce the same oxygen radicals as Ozone when it comes into contact with UV light. If you messed with it you could find a way to combine it's solid nature (it's most often sold as a powder) as a particulate filter and it's photo-catalytic properties.
http://manshealth.hostei.com
Chlorine tablets are a lot nastier than the chlorination process itself, because you might as well start putting bleach in your drinking water.
I would not need any type of storage for ozone as it would be used as it was created in the device.
Along with ozone, a bubbler would also aerate water which is one step of the sanitizing process.
Put your filtered-but-not-sterile water in a clean bottle, and stand in full sunshine for at least six hours.
The UV in the sunlight sterilises the water - if the heat of the sun also gets the water temperature over 50°C, sterilisation is three times faster.
SODIS.
A far more popular way to sterilise water in third world countries is UV from solar exposure. It requires no chemicals and no electricity which allows it to be done it even the most low tech location.
The main problem that chlorine, ozone and UV all share is that their effect is mostly to organic matter in the water. None reduce salinity, heavy metal content or contamination from things such as pesticides. These require further water treatment methods and are the largest barriers to clean water for the world.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
