3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low battery indicator
Can someone please provide me with a schematic to turn on an LED when a 9v PP3 gets low (~<20%), no microcontrollers, the simpler the better. I am hoping you can do this with a few diodes, transistors, resistors, and maybe some capacitors, but I can't think how this would work.
24 comments
Feb 12, 2011. 8:25 PMGoodhart says:
Have you tried using an IC like the following for this? MC34064P 4.5v undervoltage Sensor
Feb 13, 2011. 9:58 AMGoodhart says:
Oops. sorry for the late response then.
Feb 7, 2011. 2:52 PMkelseymh says:
Conceptually, I'd start with a joule thief circuit, so that the LED will work when the battery is low. Then, you add in a small relay in the normally closed (NC) configuration. You want a relay where the "minimum trigger voltage" is either adjustable, or is fixed at the value you want as a cutoff (e.g., 7.2V).
The idea is that as long as the battery is strong enough, it holds the relay open with some small power drain. Once the battery drops too low, the relay closes, and the joule thief kicks in to illuminate the LED.
Feb 8, 2011. 8:24 AMacmefixer says:
A typical 9V relay uses more current than a 9V battery can supply. It alone would run the battery down. The Joule Thief is not needed, and would not work at 9V. Here is one circuit that should work.
Feb 11, 2011. 1:01 PMacmefixer says:
R3 should be zero ohms or a short or jumper. Measure the voltage at Q1 base to minus. You should be able to adjust R2 and the voltage should go from 0 to a bit more than a half volt. When it gets up to a half volt Q1 should start to conduct and the LED should go out. If you measure less than a half volt, your R1 resistor and/or R2 pot may be the wrong value or out of tolerance. These determine the set point. If you remove the jumper and make R3 equal to 47k, then the pot should be able to adjust so that the voltage measured at Q1 base is a half volt. If you are getting a half volt or more at Q1 base and the LED does not go out, then you may have a problem with Q1, Q2, etc.
One quick check you can make is to put a short across Q1, E to C, and the LED should go out.
One of the first things I would check is if the Q1 and Q2 are correctly inserted. If you are using 2N3904 or 2N4401 for Q1 and Q2 then the pinout is E B C. This is the opposite of transistors such as BC547 or BC337. Also, I've taken used transistors from other projects and then used them, and found that they were damaged earlier. Use some transistors that you know are new or not damaged.
Feb 12, 2011. 10:57 AMacmefixer says:
I assembled the circuit this morning, and it worked okay.  You can read the details in my blog about it. I noticed that it is sensitive to AC hum. I was using a pot with a metal shaft and when I touched the shaft the LED glowed.  The input is very sensitive to AC. The capacitor I suggested should be between the base and emitter of Q1.  A .01 to 0.1 uF should work. Also, if you are using a breadboard or protoboard, the board itself may be causing the circuit to pick up hum.  If the board has a metal plate, ground it to the negative. But once you put the cap in, it should no longer have this problem.
Feb 12, 2011. 4:25 PMacmefixer says:
When I have had this stubborn problem, I set the circuit aside for a few days to clear my head, because I usually have been overlooking the same problem again and again. Sometimes when I come back and find the problem I say to myself why didn't I think of that before? If not, then I pull the whole circuit apart, clip the leads off, and dispose of it, so I won't have any chance of reusing a bad part. A few cents in parts it not worth hours of frustration.
Like I said in the blog, the circuit is sensitive to hum. The problem is taken care of with the 0.1 uF from base to emitter Q1.
Mine works good, the only thing I had to do was change R3 from zero to 22k to move the setting away from the end of the pot.
Feb 11, 2011. 2:26 PMGoodhart says:
A 2N3904 is s small signal NPN transister.
Feb 11, 2011. 2:17 PMacmefixer says:
I gave 10k for R5 because it will reduce the drain on the battery. If you use a superbright red LED it should help a lot.
When the voltage at the base of Q1 gets up to .5 or more volts, it should turn on and the collector voltage should drop below a half volt. That should turn off Q2.
One other possible cause of problems might be oscillations. If you put a capacitor, 0.01 to 0.1 uF across Q1, collector to emitter, it should damp out oscillations. Also, your battery or power supply should have a 10uF or more capacitor across it.
Feb 8, 2011. 12:52 PMacmefixer says:
If you find it dims when the battery gets low, then you haven't got the right values for the R3 and R2 potentiometer.  When they are set correctly, the first transistor is turned on when the voltage is 7.5V or more, and this shunts to ground the current to the base of the second transistor, keeping it off.
When the voltage drops below 7V, the first transistor turns off, the base of the second transistor gets current from the 100k R4, and the collector lets the current from the LED go to ground. The LED then lights.
I gave the value of R4 as 100k, but it should be higher, 470k should work and should save some battery current.  The R3 should be set to zero for starters, and only increased if needed.
Feb 7, 2011. 4:46 PMkelseymh says:
There are solid-state relays, which are neither large nor primitive :-) Charging cell-phone and other "smart" batteries is more complicated, as they have some built-in electronics of their own. You may need to do a bit more research (have you tried searching for "battery charger circuits" online?) to get up to speed on some of the details.
Feb 8, 2011. 8:24 PMguyfrom7up says:
This can be accomplished by using a basic opamp and a zener diode, such as:
http://www.aaroncake.net/circuits/lowvolt.asp
Feb 8, 2011. 9:11 PMGoodhart says:
Hey (waving) haven't seen you around for awhile :-)
Feb 9, 2011. 1:42 PMguyfrom7up says:
haha hey! yeah I've been busy and stuff and I just stop by once in a while.
AP Classes suck, lol
Feb 9, 2011. 3:33 PMGoodhart says:
Well, it's certainly good to know you are still around :-)
Feb 10, 2011. 2:14 PMguyfrom7up says:
haha thanks Goodhart!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
