Mains Beer?
My head occasionally says "what about mains-beer?". Instead of buying stuff to take home, you have a beer-tap on the sink.
Here is how it might work:
You build a distribution centre, which may just be storage, but could also be a brewery, and run pipes around a nearby residential area.
Each home has a beer-meter like a water-meter which is data-linked to a consumer-unit on a beer-tap on a sink.
The distribution-point provides mains-beer under gravity, consumption of which is measured by the meter and data is fed to the consumer-unit. That box displays beer consumption, and via a radio-link informs the distribution-point.
Periodically the lines will need to be flushed, here's how that would work:
> The centre switches the supply from beer to water, which is coloured with a harmless-dye, and radios the consumer-units which display the message "free beer" whilst playing Happy Hour. Consumers vigorously empty the lines while it's free.
When the water hits the meter-unit an optical-sensor calls the consumer-unit to shut off via a solenoid-valve, the consumer-unit reports back to the distribution-centre that water has reached it. After a set period the distribution-centre radios the units which haven't yet reported water to open (solenoid). Any units failing to give an adequate response within a reasonable period are radioed to display a "fault" message and flagged for a service-visit.
The distribution-centre then switches supply to cleaning-fluid, and messages all consumer-units to display "cleaning!" and open up (solenoid). Once sufficient flow has gone through each meter, they shut off (solenoid) and radio-back. Then a water-flush follows in a similar way.
Once the lines have been cleaned, the supply is switched back beer, the consumer units run until they no longer read "water", plus a bit more to clear dead-volume between meter and tap. Then the consumer-units display "read to dispense fresh beer".
Pros:
Beer is chilled by the ground in which piping is laid
No packaging-costs (cans / bottles / kegs)
Less transport costs
Drinkers have an almost unlimited supply enabling them to drink more than they might otherwise.
No more beer runs when the game runs long or uninvited guests show up (Re-design)
Consumer units can display total quantities dispensed, with cost and "don't you think you've had enough?"
Cons:
Initial infrastructure cost
It'll work best with poor quality-beer
Well?
Picture of Mains Beer?
1-10 of 31Next »
you put alot of thought into this did'nt you? you must like beer
lemonie (author)  Zaphod Beeblebrox7 years ago
Yes I did - got any suggestions?
L
maybe people could sighn up for different beers,give the consumer unit a breathalizer and it would only give you beer if you were under the legal limit.(of course if this actually happened someone would make an instructable on how to get into the unit and make it give you more/free beer etc.)
The beers would be on a cycle. Breathaliser? In your own home I wouldn't see the need. But the tap could report how much you've poured and ask questions like "hard day at work?" "having a party tonight?" "don't you think it's time you went to bed?" etc.
L
Joe Martin8 years ago
Don't underground pipes gain heat not chill them, Ground source heat example ;)
I wouldn't mind a voddy tap if you could sort that out!
lemonie (author)  Joe Martin8 years ago
It depends. Deep ground tends to maintain a fairly constant temperature. If you're piping "cold" in you'll extract heat, if it's "warm" you'll cool.
In my replies previously, the spirit-system:
That would be the neutral-spirit system. Pure vodka is supplied and you have a Wunder-bar system add concentrates at the dispense nozzle.
You'd have a tank buried in the garden and a truck would turn-up once a week like at a filling-station. (or more often if you had a lot of parties...)
L
Doctor What8 years ago
*gigglesnort*
What an awful idea.
It would eliminate drunk driving all together.
I think that Kahlua would be better on tap though.  It doesn't taste like ****.
lemonie (author)  Doctor What8 years ago
That would be the neutral-spirit system. Pure vodka is supplied and you have a Wunder-bar system add concentrates at the dispense nozzle...
L
 Like adding syrups to club soda to produce certain variations of soda?
Exactly. Except in that project you'd have a tank buried in the garden and a truck would turn-up once a week like at a filling-station. (or more often if you had a lot of parties...)
L
1-10 of 31Next »
