loading
Make any pair of headphones wireless.
I need to reduce cords on my device, as much as possible, for a project I am working on.
I really would like to convert this device from wired to wireless.
First I will explain the images, then the 2 ideas I have.
First image "before" = A device with a long headphone cord.
Second image "after" = Idea of solution #1.
Third image "better" = Idea of better solution #2.
Idea #1 - The less-preferred method.
For this idea, I'll need to cut the cord with a pair of scissors and rewire the ends to eliminate the excess cord, to achieve the results in the middle image. So How do I go about doing this? And is there a better way?
---OR---
Idea #2 - The more preferred, long-term method.
Observe the third image (idea #2). Is there any way possible on this earth to achieve this? I think it is absolutely crazy that I cannot find this kind of device anywhere on the market yet, in our day of technology.
Thanks for your comments!
Picture of Make any pair of headphones wireless.
1-10 of 19Next »
samaddon3 years ago
Try this one : https://www.instructables.com/id/DIY-HOW-TO-MAKE-WIRELESS-HEADPHONES/
vishalapr5 years ago
Why not make an instructable on this! It would be really cool!
dbanghart5 years ago
So I think what you all are looking for is this http://www.dealextreme.com/p/bluetooth-2-0-a2dp-avrcp-stereo-music-receiver-and-handsfree-black-8422 enjoy...
master120346 years ago
ok you wanna get a cheap fm radio and an ipod fm transmitter then connect your ear buds to the radio and sync the channles and enjoy
easy, take a female audio jack soder about a 50 feetcoiled copper wire to the positive terminal pins. Then to your MP3 take a cut male audio jack sodder about 50 feet coiled copper wire to the let/right wires and click play and hear youur music.
how it works- the coild produces and elctromagnetic field which is picked up by your headphones and music!!
Yes, it may work, if the coils are less than an inch near eachother... Also, It does create a magnetic field, but one nowhere near close enough to send a signal past 5 inches (I have tried this, it does work, sure, but useless to what the author is asking.) Also, again, it is not that easy.
joelleemn7 years ago
I found two devices that should work.. I hope a more affordable packeage deal can be found or made
www.mobilecityonline.com/wireless/store/productdetail.asp
www.macmall.com/p/5012956
jabcoolman (author) 9 years ago
Its worth mentioning that my device is not headphones. I cannot simply just buy a set of wireless headphones. I want to covert my device, which uses a headphone jack, from wired to wireless. Imagine plugging your wired headphones, or guitar or whatever, into a dongle that sends the signal without wires. Has no one else thought of this?!
Ah I got you. I think... Your headphones plug into the receiving end, and the transmitting end can pug into any headphone out jack. Am I correct?
jabcoolman (author)  its a lion9 years ago
Yes, you are right. Thats the idea I have, to have anything that receives signal to receive it wirelessly from a dongle that plugs in where the headphones jack would. Any ideas on how to achieve this? Bluetooth would be optimal, I hear the a2dp technology would help this! But its not required. Also, the range doesn't have to be long. I will be always near the wireless dongle, probably between 1-5 feet average.
1-10 of 19Next »
