Make supercapacitors from graphite in a DVD burner
The outline is that you can deposit graphite oxide (a cheap bulk material) onto a film of PET (the plastic used in Coke bottles), hit it with a commodity infra-red laser (such as the one in a $30 LightScribe DVD burner) and end up with a form of activated carbon material that can be used as the electrode in an electrolytic capacitor.  Add some aluminium foil, separator membrane and electrolyte and you've got cheap, robust energy storage.
The headline numbers are a few hundred milliFarads per cubic centimetre at a few volts, which works out to 1.36kWh per cubic metre of stacked capacitors.  It's still about 50 times less energy per volume than lead acid batteries, but you could store as much energy as your house will need overnight in the size of a garden shed or a set of bunk beds.  They charge/discharge in seconds and retain >95% capacity at 10,000 cycles so seem suitable for storage to even out intermittent energy generation from, for example, solar or wind power.
I'm really thinking about cost here- unless I'm missing something fundamental it doesn't seem like producing these on a high volume roll-to-roll process would be excessively difficult, and the cycle life means the replacement time would be many years even in heavy usage.  Could you get sufficient kWh per dollar to make these a viable storage mechanism for home-scale renewables?
There's a more informative article here.
Picture of Make supercapacitors from graphite in a DVD burner
Kiteman5 years ago
What's the guess on how it takes to get from "product goes on sale" to "teen shoots down light aircraft with coil gun"?
