3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own philips screwdriver?
If I want a flat screwdriver in an odd size, I can take a piece of metal, heat it, pound it flat on one end and file or grind to shape; something within reach of even the clumsiest blacksmith. Is there some trick I'm missing that allows similarly simple home construction of a philps-style screwdriver? Or are they part of a plot to allow only factories to make screwdrivers :-)
22 comments
Apr 4, 2009. 6:09 PMBambooNut says:
Do you have a set of jewelers files?
A barrette file should allow you to cut the proper angle.
I have never ordered from this company, but here is a link:
http://rmgsupply.com/products/BARRETTE_FILE_3_CUTS_6_1_4-646-111.html
Jun 5, 2007. 5:01 PMmf70 says:
[quote]Or are they part of a plot to allow only factories to make screwdrivers :-)[/quote] Well, yes. Phillips screwdrivers were developed to make it easier for factories to turn out zillions of widgets. Since they were designed in the ~20's, they were designed by engineers that had access to modern manufacturing methods. That said, if you want to make a Phillips screwdriver, the "trick" is to use a small "V" shaped grinding wheel so that the notch comes out parallel at the edge. Jtobako's idea Is a good one when you need a particular style RIGHT NOW. There are differing opinions on whether the tip should be sharp. If your opinion differers from the maker of the Phillips screw, you won't be doing much driving. You may have to grind the very tip of the screwdriver back a little bit. (Actually, the differing ideas about points are particular named screwdriver styles.) Mark
Mar 15, 2007. 9:41 PMvatosupreme says:
What size exactly are you trying to make?
Apr 11, 2007. 4:46 AMVendigroth says:
perhaps a bit of steel rod, carefully shaven to size using the cutting wheel and engraving burrs of a dremel?
Mar 16, 2007. 8:36 AMjtobako says:
amazingly enough, screwdrivers are made to be softer than the screws. that way, you don't destroy the (presumably) valuable equipment with a stripped screw. many cheep tools just need better hardening. try heating the tip to just past red hot and quench quickly (small items loose heat quickly enough that it may take several trys).
Mar 15, 2007. 7:17 AMsam says:
grrrr... I hate the screws on nintendo 64's.. My friend's was broken, and I knew i could probably fix it.. but those stupid screws made it so much more complicated than it had to be!
Apr 7, 2007. 8:44 AMcastcase1 says:
So do I and what's more that may cost much
TubeHunter downloads YouTube/PornoTube/xTube/yuvutu/LubeYourTube videos to MPEG/iPOD/PSP
http://www.neoretix.com
Mar 15, 2007. 7:32 PMcanida says:
Phillips screwdriver? That's easy... ... ... Vodka + Milk of Magnesia. *ducks and runs*
Mar 17, 2007. 7:02 AMcornflakes says:
What about taking some metal rod and drill in to it to the right shape (?CNC?)?
Mar 15, 2007. 3:12 PMlemonie says:
I would buy / find the cheapest screwdriver abailable, as they tend to be fairly soft. Then hacksaw the existing tip off, and cut a new tip with a metal file. I'd then be looking at heat-treatment.
W/ref jtobako - the only McDonalds toy I dismantled had it's screws removed with a soldering-iron. It was then destroyed with match-heads.
Mar 15, 2007. 6:54 PMjtobako says:
any of the mcdonalds toys that make noise are worth taking apart. sometimes with a hammer : ) the trick with the metal file is getting a GOOD file with a sharp, square corner and then keeping it even.
Mar 15, 2007. 6:59 PMlemonie says:
I prefer fire and explosions... But yes, a good file is important. Hardening your tip afterwards I'm not too sure about. I did tour a gear factory that used e.g. tempering, case-harnening & shot-peening, maybe I'll try to build something like that (big project I think...)
Mar 16, 2007. 8:25 AMjtobako says:
casinite (sp?) is a commercial product for case hardening low carbon steel. you heat the metal red hot, dip it in the powder (a cyanide product, but safe if used the right way), re-heat and, if i remember correctly, quench.
Mar 17, 2007. 8:38 PMPaladin says:
I've heard of people just using used motor oil - lots of carbon.
Mar 18, 2007. 12:39 PMjtobako says:
i've heard of using motor oil to quench, but not for case hardening.
Mar 19, 2007. 7:43 AMPaladin says:
You are right. I've read it used to harden the steel throughout and not just the outer layer. It could make it brittle. Supposedly it would add carbon to the outer layer.
Mar 19, 2007. 8:47 AMjtobako says:
oil is a 'soft' quench-it doesn't cool the metal as quickly as something like water ('hard' quench) does, so the metal doesn't harden as much (it has to do with which crystalline structure the steel is 'frozen' into and how much of each form there is). the harder the steel, the more brittle-some fully hardened steels will shatter like glass if dropped on the floor. (not a good thing when you just finished putting several hours into a knife : P) at 0.005-.010 inch per hour over 1750 degrees F, it's a very thin layer of added carbon.
Mar 15, 2007. 6:43 AMjtobako says:
the 'easy' way would be to make a flat screwdriver that fits half of the cross. the trick with philps-style is that there are several different profiles, some with a very sharp tip and others with a much blunter tip. the plotting part is when you start getting into torx, security torx and the triangular heads on nintendo and mcdonalds toys : )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
