Making a solar compass
For instance, today the sun is just over 23 degrees off its equatorial path. So you have a stick pointing straight out from the mount at a right angle and you just angle it down by 23 and a half degrees.
So you tighten it in place at that angle. Next you combine rotating the entire thing on the ground (keeping your latitude angle correct) and you rotate the mount itself until the stick points straight at the sun. At this point, no matter where you are on earth, your mount is inclined in line with north/south.
I have 2 little test compasses to try this but it was fully cloudy all day so I cannot try it out.
One uses a Fresnel lens and the other uses a magnifying glass to line up the sun.
Just wondering if anyone else has done something like this? Solar compasses did exist and I had a look today. They do not look like my thing at all. They look really complicated!
I will post a year of inclination data shortly.
Thanks Brian
11
comments
Add Comment
I believe Mark 2 is much better. It is also much easier to make. You might even have all the parts right now.
I would really like it if people give it a try. Here it is
Thanks
Brian
Interesting piece of kit. Having seen it and thought about more, you've got the time of day built into this with the chart and position data.
L
But, I think my explanation is more understandable.
Having made the first one, I think the next ones will be a lot easier (and a lot smaller and a lot different).
Really, all you need is a few pieces of ply wood, hinges, the chart and a little protractor or photocopy of protractor.
(But it is so hard for me to visualize this before I make it).
Supposed to be cloudy all day again. Darn!
Thanks for your interest.
Brian
L
You do need to have the right time though.
If you think of marine navigation with a sextant, a ship's clock is essential. There you're doing a related operation to find latitude.
At a fixed location you can mark north and leave it, for portable you'd need to know your time and position?
L
I hope!
The only things you are allowed to adjust are the direction that the latitude angle is pointing and you are allowed to rotate the thing that is on the latitude angle too.
There is only one combination of those adjustments that will point at the sun.
Once you get it pointed at the sun, you can read off the solar time if you have a protractor set up to do that on the latitude axis.
Its pretty neat actually (if it works).
Total cloud cover right now (and I have not fully made it) so very little chance of testing today.
I might be able to post pictures though.
Thanks for the interest
Brian
The sun as I see it has a time-of-day inclination variance. I think you'te compensating with the latitude angle, is that it? (getting it slowly I think)
L
So I decided to test inside using a light as pretend sun. One little problem. There are 2 possible norths!
I don't think it is a big problem. One should be stationary and one will move.
(The moving one is not the real north). So if you have a good idea what time of day it is, no problem. But if you have no watch or it is near solar noon then 2 readings half an hour apart should clear up any doubt.
I actually have 2 prototypes and they are quite different.
If this works well and solar compasses become something used and useful, they will probably look nothing like my prototypes.
(Just so you know)
Brian
I believe most people find north south BEFORE they set it up.
(And it is critical to find it). But if you know the inclination AND your latitude, and set them up accurately enough, you can use the mount itself to find the north south line , simply by pointing at the sun!
Anyway, thats the theory.
Will it work in practice?
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
