Making the battery hand gun safer?
Okay, so I guess we can all agree that the battery hand gun is dangerous, so this is my plan to make it safer. I'm not sure if it would work though.Any ideas? I would put the pipe #1(original) into a bigger pipe (#2) and then fill the gap with clay to act as a "shock absorber".In theory, the clay would absorb some of the shock, and IF it did explode, the smaller pipe will fly out of the bigger pipe instead.Therfore, it would reduce the chance of the pipe exploding in your hand. What do you think?
sugg2210 years ago
i know i'm way late on the topic, but the way to do it is: a layer comprised of half-inch blocks of rubber alternated with half-inch blocks of soft clay that has not been baked, with a quarter-inch gap in between each block. that is a great shock suppressor.
IlluminatedAntichrist (author)  jtobako10 years ago
What if I made the first pipe removeable so I can check it every after use?
that's fine-IF you are going to do it EVERY time.
lemonie10 years ago
The whole thing is hazardous. Clay won't absorb shock, but a stronger barrel is less likely to burst. Firing things through doors is still a bit dangerous though...
IlluminatedAntichrist (author)  lemonie10 years ago
So I guess I will just take the steel pipe and put it into the bigger pipe then.
or I can just find the most thick pipe, incase the barrel in wood along with a handle to make somewhat of a gun without a trigger.
anything around the barrel makes it less likely that you will see signs that it's failing (cracks, bulging, temper lines-discoloration caused by heat, rust/corrosion, ect) makes it more dangerous. that said, you could wrap the barrel with iron wire if you can't find a tightly nesting set of pipes. or learn to cast aluminum and cast an aluminum shell around a steel liner.
I would suggest putting this in the original instructable.
