loading
Mauser C96
Greetings,
So, ever since I saw Chuunibyou, I've wanted to try my hand on a Mauser C96.
Once again, it's a model, based heavily on Aug5om3's version.
I built his one, then changed the handle, trigger and shortened the barrel a bit.
The handle is a bit less sturdy than I like, but it looks pretty IMO, though the front of it could use some more curving.
It features:
- a comfortable handle
- charging handle
- moving hammer
- pretty good looks
I'm not entirely happy with it, but as I have plans for other builds, I decided to take some photos to share, and then take it apart.
Posted it as a forum topic, as it isn't original enough to warrant a full slideshow.
Tell me what you think in the comments!
1-10 of 15Next »
Not bad bro, and its great to see new stuff from you!
Thanks.
Yeah, it's fun build again, when I get the motivation, haha. I have a few things to build next, so that shouldn't be that big of a problem anymore :)
Very nice, it doesn't look as good as some of your work, but you could clean it up a bit easily. I agree with Dunkis, it should be easy to make it shoot.
dr. richtofen (author)  CorgiCritter2 years ago
Thanks.
I know this isn't the greatest, but I cleaned up the barrel a bit, which looks a bit smoother now. Pistols in general are pretty hard to replicate with K'nex.
It can shoot now. More information about that is in my latest reply to TheDunkis below.
Agreed. It is nice that it shoots now, that is a improvement. As for it blocking too far back, you could remove the blue clip on the trigger block, or replace the green rod and blue clip with a cut rod end.
I did that trigger update, and yeah, it does work better. I haven't tested it with a big rubberband yet, but it's smooth and stable with a normal, small rubberband.
It's probably the last update on this gun, as I have some more stuff I want to build next.
Sweet, looks very good. :)
Kona-chan2 years ago
pew pew pew
TheDunkis2 years ago
I think it could easily be converted into a shooter without compromising looks at all. Give it a go, man.
dr. richtofen (author)  TheDunkis2 years ago
It should definitely be possible to fit a trigger in it, barrel's easy to fix for when it shoots.
I'll give it a try tomorrow, the biggest problem will probably be the handle when pulling back the pin, as it isn't the sturdiest.
1-10 of 15Next »
