3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Minor flood - Check your overflows ! ! !
Just had a minor disaster here - Water dribbling through from the roof into the airing cupboard because the float valve on the hot water tank had stuck and the overflow pipe to the outside was blocked.  Rapid turning on of hot tap and leaning suicidally out of the window with a length of stiff copper wire to unblock the pipe averted a worse situation.
The overflow appeared to be blocked with mud, and this is not the first time it happened.  Some years ago this happened in daylight and I could see the pipe was also full of mud and small pieces of stick.  I suspect that some insect - possibly a bee - had been nesting there.  Order of the day tomorrow is to put a one-way flap type arrangement over the overflow to stop it happening again.
But this has also reminded me it's time to make some safer accommodation for bees, ladybirds etc for overwintering.  I'll be knocking up something like THIS tomorrow and maybe they'll leave my plumbing alone!
2 comments
Sep 17, 2011. 12:29 AMKiteman says:
Maybe also add a mesh basket over the end of the overflow?
Sep 16, 2011. 5:22 PMiceng says:
We have a Reno gas water heater with a top pressure release calve that
I had plumped down the along the tank and turned horizontally to the outside.
A perfect candidate for the bee in question.
Tested it at your behest and it flowed clear and out.
Thanks for improving my sleep tonight.
A
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
