loading
Motor for ceiling mounted cargo box storage lift?
Hi there,
A year or so ago, I purchased a Thule 571 Roof Mount Cargo Box Storage Lift and installed it on the ceiling in my garage.  The ceiling in the garage has a fairly high ceiling though and using the crank that came with the lift is a bit cumbersome to say the least.  I usually have to stand up on a tire of the car in order to reach the crank to turn it efficiently.
So the idea popped into my head that wouldn't it be really cool to connect a reversible electric motor to the lift so I could just flip a switch to lift it and then toggle the switch down to lower it.
Here's a link to the specific product I'm using, which I think Thule has discontinued because I couldn't find it on their website tonight:  http://www.overheadgaragestoragesolutions.org/thule-571-roof-mount-cargo-box-garage-storage-solution/
My questions:
1) What size/spec motor should I get?
2) Where can I get the motor from?
3) I'm assuming that any electric motor can be reversible just by swapping polarity in the switch?
4) Do I need a belt to ensure that the motor doesn't spin the worm gear too fast or should it just be a direct connection?
5) Any other thoughts/ideas?
There's an open 110v outlet in the ceiling of the garage where the garage door opener is installed, so I could run a power cord to that outlet and then I presume I'll need to run a wired switch down to the wall of the garage where I want to be able to control the lift.
Thanks in advance for your time and consideration.  This would certainly make my life a bit easier to be able to quickly and easily raise and lower my ski box onto and off the roof of my car.
Regards, David
