COMMUNITY : MAKE
Mounting Lenses On Your Microscope
I found a broken cell phone with it’s camera and wondered if the lens could be used as a microscope objective. Image A shows the lens and it’s mounting with the CCD. The back of the lens is shown. The lens is about 4 to 5 mm in diameter.
The starters from florescent lights make good lens holders. Image B shows a starter along with my modifications to hold the cell camera lens. The starter tube has 4 slits along the length so it can be compressed to fit the turret of the microscope. Image C shows it mounted on the turret.
Image D shows the resulting view of a feather. It’s quite bad. Image E shows, for comparison, the view through an ordinary 20x objective (.40 NA).
Here are some more lenses that I tried:
Lens from a discarded flatbed scanner..... Very good!
Lens from a 8mm movie camera...... Fair.
Lens from the laser pickup of a discarded CD player..... Almost worthless.
To take pictures through the microscope, I used eyepiece projection with a wide angle eyepiece. The lens on the camera was set to wide angle and maximum aperture, with a remote used to trigger the shutter. The camera’s LCD was used to focus and adjust the image. The camera’s autofocus handles the rest. For even illumination, be sure to center the objective lens over the substage condenser.
ShutterBugger (author) says: Jul 9, 2010. 8:56 PM
I used a European Standard microscope.
billbillt says: Feb 27, 2011. 3:58 PM
I think this is very cool. Could you give details to what is inside the starter can please? I would like to know how you added the lens inside.
Thanks!
ShutterBugger (author) says: Feb 27, 2011. 9:31 PM
Originally, the starter has a momentary switch that opens back up once the florescent tube lights. These switches are easily removed.
The lens is dropped in and centered with small pieces of paper towel, Q-tips, or whatever else is available.
~Bob~
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
