Music box concept + Guitar guts = Player Guitar
for christmas i made my brother a (somewhat poorly constructed) lap steel guitar. seriously, it wasn't that good, but it worked and it was more of a "can i do this project" kind of thing, plus he has a friend who is an ACTUAL luthier so he's going to "redo it"....
anywho, i made said guitar using zither pins for the tuning pegs and it got me to thinking. with the zither pins you could theoretcially have a guitar string of any length and use the pin to set that string to any given tone on any particular scale (say the functional length of the string was only 3 inches....you could still theoretically set the tune on that string to a semi permanent desired tone). so, with a bunch of short lengths of various guage strings you could create a guitar music box (probably more of a music barrel but, whatever).
now, normal music box has the tone pins (not sure what they're called...but the tuned slivers of metal) stationary along one (or more) fixed planes and a revolving "picking" drum that strikes each pin to make the tone in the order that it needs to be in a piece of music. for whatever reason.
so, combine these two ideas and you get a player guitar, or a guitar based music box, whatever.
so, obviously this could be acoustic or electric. my personal preference is to lean towards electric, so that's where the question comes in. a normal guitar pickup has 4, 6, or whatever magnets fixed within it's coils so that you can pickup the signal from 4, 6, or whatever strings that are strung paralell(ish) across the guitar. for the music box concept to work (as opposed to a true player guitar that plays across the strings) the individual string pieces (that are all individually tuned etc) wouldn't be able to be parallell to each other like a normal guitar. they'd either be in line on the same plane or spaced out in odd ways (i've got an odd concept for the actual construction...where the strings do the moving and the "strummers" stay put).
so, does a single magnet pickup exist? that could just be wired up into the rest of a normal electric guitar's circuitry? or would i have to build such a thing from scratch (and subsequently how would i do that)? would a normal electric guitar's circuitry be able to work the same with more than 6 pickups in play (thinking of a cheap one from a pawn shop...that's what i built the slide guitar from)?
also, taking song suggestions and subsequent individual string tuning plans
*i do know that there are "better" ways to make a self playing guitar that uses the normal guitar form factor and robotics and such....but this seems more fun. plus, i might make it into a wind powerd thing...electric guitar windchimes anyone?
4
comments
Add Comment
You might run into impedance issues when wiring a single, huge pickup, though. Some modifications from the standard pickup wire might be needed. Not to mention the practical challenge of winding such a thing.
But many guitars (particularly oddball MIJ 60's guitars) have had 3 or 4 pickups wired both in series and parallel...or a mixture thereof. I'd try that with cheapo pickups first, before spending months experimenting with different magnets and wire.
Besides, you'd have more layout flexibility with multiple pickups, so your multi-plane idea will be easier to implement...
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
