My Grand Tournament Entry TDAP (new* Official TDAP)
Alright for lack of a better name for now this is just TheDunkis' Assault Pistol. It's a compact pistol made specifically for war. I did make a video but I can't upload it using my mom's computer so...yeah. Anyways they're three things that make this the almost ideal war weapon.
1. It's compact. Usually no wider than the average person at the age of...I don't know I'm skinny so probably a 12 year old lol so it should be easy enough to carry around as a secondary weapon.
2. High Cap magazine. It holds I think around 25 green rods. I know green rods aren't the best rounds but typical wars happen in homes where distance doesn't count as much and for bigger battles it would be more of a secondary weapon.
3. Removable magazine. It's based off of Zak's from KI. It clips in and out really easily but it's really sturdy so it should never fall out even if you're shaking it around.
Alright so as I figured the gun wasn't enough to make it through. I still wanted my own assault pistol that works though (I'm hoping that we shift over from side arms to these as they'll be easier to make original). This is based off of the original in some design like the handle. It uses what I believe to be the first slanted and open magazine for blue rods. Why slanted? Simple three reasons. 1. It looks kind of cool. 2. It acts as a hand guard. 3. It's keeps it compact so it's not sticking out but it also feeds ammo towards the front more so that it gets more power. That's the main reason anyways. I have plans for this gun if I keep it around anyways. This is the simplest design with no special details or anything but I'm hoping to make a smaller and larger version with extra features. For example the larger will most likely shoot yellows possibly with a removable magazine and a stock. The smaller will use white rods maybe with a slide and maybe with the magazine in the handle (although with a similar open mag style. I figured it out I just need to figure out how to connect them).
Here's what I rate this new version compared to the old one. *newer version
1. Size Efficient. 4/5 It's compact but not as small as it can be. *4/5 It's pretty much as compact as it will get but you could make it ultimately smaller.
2. Power and Range efficiency. 3/5 At the moment it's about average but I havn't really perfected the firing system. Sometimes it doesn't even fire well at all so I have some work to do. * 4/5 It's a whole lot better now. It's decently powerful for its size but obviously not a sniper or anything.
3. Accuracy. 3/5 I haven't honestly tested it a lot yet only enough to know that it fires but by the time I'm done hopefully this should updated to be a 4 even though it's more of a CQC gun. * 4/5 I tested it a couple of times and it hits very close with the sight I'm using. Still not perfect.
4. Easy, fast loading. 5/5 With removable magazine that is super easy to put in and pull out this is one of those "as good as it gets" in the fast loading department. * 3/5 Ugh this is where it fails. The good news is that it's still pretty to load. All you need to do is push blue rods through the barrel. No need to be precocked nor do you need to hold the pusher down just push the blue rods in and down. Should hold about 10 blue rods maybe more.
5. Handling. 4/5 pretty standard I guess. The handle ain't bad and the trigger is smooth enough. So far the gun doesn't work the way it should but that will be fixed before I'm done obviously. The magazine area makes for a good forehandle when not using the shroud. * 4/5 Still pretty standard expect I traded around a couple things. The angled magazine does not make for a good foregrip. It works but I don't care for it. The handle is the same but the back was changed to be a little more comfortable. The trigger works better.
6. Cocking. 3/5 Not super bad and not super good. I'm not sure if I should put a slide on or not. * 3/5 same old same old.
7. Looks. This is another one of those love it or hate it things but I think it looks good all but the support on the bottom which I put on for more of function than looks but I do think the gun looks better with it. * I'm not sure which I like better. I struggled with the looks on this one for awhile and tried adding a lot of pieces. I finally ended up getting rid of pieces instead until I finally got what I wanted. I think this version looks better good.
8. Reliability 2/5 So far I'm not going to lie the gun isn't the best but like I said it ain't working right by the time I'm done I'll make sure it's working 99.9% 5/5 The only problem so far is that sometimes two shots try to go at once and they just fall out from the friction. It only happens if you don't load the ammo right. Edit: Fixed updated design doesn't jam anymore.
9. Other features. +1 (judged on about how good the extra features are. Anything that doesn't fit above will be included in the score which will add the amount of points as a bonus into the final score) It has a simple rail nothing to special and a simple mock silencer shroud for the barrel with a forehandle. I think it makes it look better but bigger. * +1 this version doesn't have anything super special. The best is the open magazine which I figure deserves a +1 on it's own considering how useful they are.
God any other ideas for my newer gun? I'll probably want to post but I also want to work on a Master Sword V2 really soon and I need all my pieces for it. I might go out and buy another bucket soon but if I don't then this might go by by. I'll try getting a video as soon as I find what I need for the camera>computer hook up for videos. How do you think it would compare to the BBKWG and Spiff (along with the other APs those are just the most popular)?
Picture of My Grand Tournament Entry TDAP (new* Official TDAP)
1-10 of 122Next »
gabhoot8 years ago
post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post
amtdude9 years ago
post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post post
TheDunkis (author)  amtdude9 years ago
It's gone... but I have two alternatives for you. I'm working on my official assault pistol and am about to get a picture or I'm going to make an MP7 with the same type of removable clip in the handle.
your old age pensioner lol. OAP
knexguy barrax8 years ago
Yeah, hopefully he doesn't name it that :)
barrax knexguy8 years ago
lolz, i hope he does, not being nasty though
Lol.
lolz/ quick reflexes huh? 1 minute away
Lol, I just got a comment for Yerjoking that was posted 0 seconds ago..
Its 'cause I'm bad =P.
1-10 of 122Next »
