My old speakers have no plug, what do I do?
Here is my problem: I found two old speakers that I want to set up in my room with my Xbox (Original, not 360) and would also like to be able to plug a MP3 player or whatever else into it, but mainly just the Xbox. However the wires are just bare, there's no plug on it or anything.
So how would I go about fixing this? I was hoping I could just take a simple audio in/out cord and snip the end off and attach it to the speaker, but I've never worked with audio before, so I'm a bit lost.
Thanks for any advice :)
And P.S. I'm good with electronics, I've just never worked with audio/speakers before.
11
comments
Add Comment
. Pick the left side or right side terminals on both speakers (doesn't matter which, just as long as it's the same side on both drivers), and wire them together for the common. Use the other terminals, as appropriate, for left and right channels.
. After you wire it up, if it sounds "muddy" then the drivers are out of phase. Swap the wires on either (but not both) driver. "Absolute" phase is unimportant (it doesn't matter if the drivers push or pull), but the drivers must be in phase with respect to each other (they have to push/pull together). No electrical damage will occur, but the sound quality will suffer.
That's much better defined than my comment, and probably worth it too.
L
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
