Need an 8 foot super rigid tube that needs to beak down into 2 foot sections
Hi --
I need to create a tube that is as small diameter as reasonable, relatively lightweight, and very stiff. It will be supported only on the extreme ends (thus the need for stiffness). There will be a comparatively light load, equally distributed over the entire length of the tube when in use.
The thing needs to build up to 8' overall, HOWEVER, no single section can be longer than ~2' when broken down.
My first thought was 1" PVC - it's NEARLY stiff enough, but a trifle bulky, and it does droop in the center by about 1.5". 3/4 EMT tube is great, and stiff over a 10' span (when in one piece). Problem is how to connect the sections together. Typical off-the-shelf EMT junctions tend sag just trying to support the tube with no load. I have a number of ideas that are likely overly complex and stupid, but was wondering if y'all might have a something that I have not thought about.
Thanks!
Ted
grayhairguy4 months ago
Search goggle for telescoping steel tubing like Industrial Metal Supply. This tubing is sized for good fit between sizes.
McMaster - Carr industrial supply has with or without holes in steel and other metal materials. They are fast and easy to order for individual accounts.
ilpug7 months ago
Carbon fiber tube? you can get it cut into 2 foot sections and then use some aluminum rod to make a plug connection at the ends of the pieces.
Toga_Dan7 months ago
if u find tubing. That fits snugly over another size tubing, that's an option for diy couplings. A 2 inch long coupling won't be as stiff as a 2 foot one.
kelseymh7 months ago
The EMT is a good option, but it'll be fairly heavy. In addition to the four 2' section and joints, get some approximately 6" to 1' sections of either more EMT or PVC, with an OD that matches as closely as possible the ID of your EMT. Slip those in at each joint, secure inside with, for example, museum wax or earthquake putty, then close the joints.
caitlinsdad7 months ago
Get a longer saddle clamp or a long piece of pipe section that fits on the tube to splice the joint. That will keep the joint from flexing. The EMT fitting is meant to just connect two pieces.
Downunder35m7 months ago
Take some wire and pretension the tube ;)
morgan834 (author)  Downunder35m7 months ago
Yeah, I thought of that, but I would still need something on the ends of the tube to hold the thing in alignment while applying the tension....
