Need help driving a wheel with a 180 degree servo
So for a Electrical Engineering class I have we were given a challenge, to design a robot that can go a certain distance on carpet using only servos and 3d printing (and any sensors we would like to use). I want to know if anyone could tell me if it would be possible to drive a wheel using only a servo. Maybe the same type of drive that trains use? If someone has any ideas that could help I would appreciate it.
Have you thought of how a bicycle pedal works, not the legs so much as the chain and ratchet system.
You can ride a bike by turning the crank half a turn, then back pedal half a turn and pedal again. I sometime do this on my mountain bike over slow tricky stuff because its easier to balance.
Anyways you dont need all that just a sprag clutch (Freewheeling clutch) and a wheel and your good to go.
you can get them here
http://www.smallparts.com.au/store/partscombtab/onewayclutchbearings/
iceng22 days ago
How mechanically adept are you..
Whenever you reverse the servo it engages a lift the wheel cam..
Then in forward the wheel engages the rug in traction.
Or a gear train (Lego) slip clutch that only moves the wheel forward :-)
iceng iceng22 days ago
Or here is a wild thought, how about a gear box that engages two gears in reverse and one in forward of a servo rotation using gravity to exchange gears.
Anshu AR22 days ago
I've seen people modifying their servos for continuous rotation. So, you can give that a try. :)
https://www.instructables.com/id/Arduino-Nano-base...
ebailey-kelly (author)  Anshu AR22 days ago
I wish I could but we are only allowed to use a limited rotation servo, no modification is allowed to make it continuous, but thanks for the idea.
