3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Need ideas on how to make an automatic photo slicer/cutter...
I'm playing with a digital photobooth which prints out 2 vertical strips per piece of 4x6 photo paper.  It works great, and I just cut the paper in half (the long way to separate the two strips.
I'm looking for a way to automate this.  I've tried pre-perforating the paper, which works but is not ideal.  I've also just manually used a paper cutter (both rotary and guillotine style).
My goal: an automatic paper cutter that will cut a 4x6 photo in half the long way.
I've actually started building a device that is basically a slot to guide the paper, and a turning rotary blade.  The paper gets dropped in the top, is drawn through the turning rotary blade in the middle, and is spit out the bottom.  It works on small scraps of paper, but lacks the power to really cut through an entire piece of photo paper.  Also, it's built out of MDF wood and I lack the tools to make it precise enough to cut accurately.
The cutting mechanism seems to be the big holdup.  I tried with my hand - a rotary blade (even a big sharp one) requires quite a lot of pressure to cut the photo, and it's not something the photo paper can just drop through via gravity.  I'd have to get a much stronger motor.
But I'm starting to brainstorm - is there a better way?  I think ideally I'd have a mechanism like an electric paper shredder - two rolling bars with disc-shaped metal blades.  The blades are not thin & sharp like a razer... just sharply-square on their edges so that paper get gets caught between them gets cut.  I'd have a paper shredder with just two of those roller/blades, so it would just cut right down the middle.
However, all paper shredders I've found are cross cut (which would pulverize the photo), or have grippy teeth that mangle the paper leaving very rough edges.
So let's brainstorm... what kind of cutting mechanisms might work?  What are make-able in a garage with limited tools?  How could I create my own custom paper-shredder type roller-blades?
Any ideas, thoughts, questions are welcome.  It seems simple on the surface, but I've built two prototypes and still don't have a workable solution.
Thanks!
(And yes, I'll turn it into an instructable when it gets done)
SUMMARY:
(I'll try to summarize the current ideas here)
-Use a mini saw blade and work it like a mini table saw.
-Create some kind of rotary die cutter.
-Automate a normal guillotine paper cutter (lots of electronics and sensors).
12 comments
Nov 5, 2010. 4:30 AMnutsandbolts_64 says:
I'll get to the bottom of things: Use paper tape to control which motor turns on or off. The tape is punched with holes, reader has electrical contacts. If the hole is there, contacts touch and turn on the motor. If it's not there, contacts don't touch and nothing happens. Use as many rows on the tape as you have motors. Each row controls a specific motor. If you research into paper tape, you may get ideas (for example, it was used on CNC machines). That way, it is completely automated. The only thing that isn't automated is the motor that is making the paper tape go round and round and round...
Nov 4, 2010. 10:14 AMjeff-o says:
I wonder if you could modify a strip-cut paper shredder, so that it only cuts in one place? Combined with a feeder slot, you could drop your photos in one end and they'd pop out the other side cut straight down the middle.
Nov 4, 2010. 12:22 PMjeff-o says:
Well, have you tried places like kijiji or craigslist? Hey, maybe you could get one for free on freecycle...
Nov 4, 2010. 11:09 AMPKM says:
Something like a table saw? Have the blade turning (fast) in a slot in the surface the paper slides over. It would probably shred the paper a bit but might solve the pressure problem.
Nov 3, 2010. 3:21 PMcaitlinsdad says:
If you want to make a contraption that even OSHA would be afraid of, how about using motors, screw press, or hydraulic ram to press down on a die or fixed blade that cuts the paper in two? Those industrial paper cutters have a drop blade, and some machinery behind it to generate a lot of pressure as it comes down. Using some linkages would give you a mechanical advantage.
Nov 3, 2010. 5:12 PMcaitlinsdad says:
Well, there is always cutting the paper in half beforehand, have a paperstop to guide the paper on your chopper. Adjust your printer to take in that size paper. It'll take longer to print but will spit out the cut paper without the mechanical cutter setup.
It could turn out to be a monster if you try to build a cutter since you might need a paper sensor, clamping device to activate to hold the paper, cut the paper, release the clamps, eject the paper...
Have it drop flat into a chute where is stops aligned to the blade. Have the handle on the outside of the booth. If you want your pictures, have the occupants pull down the big lever to chop their photo in half. The pieces drop out of the chute to the user.
Nov 3, 2010. 5:21 PMcaitlinsdad says:
Oh, that die thing, the guy with the passport photos uses that to punch out two regulation size photos from the photo sheet. You could probably make a similar thing to custom size your photo strips.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
