Nerf Mods
There are so many different nerf mods for ALL nerf guns, But the question is "Which one brings enough power to make a nerf gun shoot far and fast with better accuracy?" Answer is all them, if you put all the mods for one gun into one gun you are going to get a great outcome unless you do the mod bad, take a Recon CS-6 for instance it is a low power nerf rifle not good for wars at all shoots around 20 feet but, mine has been modified and i am currently looking for different modifications for it but it shoots more than 80 feet  measured, exact results are 80 on most shots 1/10 shots shoots around 50 and that is because it was a BAD DART, here is what i did,
(P.s: this will be a instructable for the mods in this....)
1 Removed AR
2 stretched out spring by plunger ( not recomended get a new spring if  you can )
3 put a spring behind plunger to create more friction which pushes the barrel  forward more and causes a stronger air push.
4 made the air tube bigger by the AR with a drill
Thats all i did it was easier than most mods i have done ( iremember the maverick i had no idea how to get into the roatating barrel)
but it led to the best outcome, P.s doing the same thing makes the Raider CS-35 alot more stronger it will more than likely shoot 90+
I will be getting a longstrike soon so i will show you guys the AR Removal and other mods i know which can be applied to the gun and create another great Nerf Sniper Rifle, Later guys.
